Old 02-14-2011, 05:40 PM   #1
LaMaR-
LaMaR- is on a distinguished road
Sunroof removal?
Hey guys I have been trying to pull my sunroof on my FC and cant seem to get it out. I was told to pull the 4 bolts in the rear which I have and It seems to be stuck in there, Is it just stuck up there and I need to really just yank on it? Or am I missing something?
LaMaR- is offline   Reply With Quote
Old 02-14-2011, 06:11 PM   #2
All the bolts on the sides... I believe 6 all totatl and I believe a few in the front as well? Don't forget the electrical connectors. And pull the actual sunroof itself out before going for the frame, that motherfucker is HEAVY!
Old 02-14-2011, 07:02 PM   #3
firzen
It's not that heavy.
Sounds like the two nuts towards the front are difficult to reach- you may have to crank the sunroof open a bit to see them.
Good luck.
Old 02-14-2011, 08:40 PM   #4
Its heavy enought to cause a 2 hr bleeder on your head
Old 02-20-2011, 12:25 PM   #5
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
LunchboxCritter is on a distinguished road
See the 4 copper colored mounts (2 on each side)? Remove the single nut from the car side on each of those.
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn.
DO NOT TRY THIS AT HOME!!!
LunchboxCritter is offline   Reply With Quote
Old 03-01-2011, 05:43 PM   #6
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
I'll get some pics up of the bolts later tonight, i dont have a headliner. Even after he removes the bolts theres those sort of studs that i guess are to get the sunroof even with the car roofline that you have to loosen.
Old 03-02-2011, 04:08 PM   #7
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
The nut in above pic with the clip thing under it need to be loosened. It does not come off of the sunroof. It stay on it.
See the brass colored bracket? Just that big bolt in the middle comes out. The bracket does not need to come off the sunroof.
