Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Goopy Performance
Goopy Performance We Manufacture, sell and build Rotary engine parts and accessories specializing in Big horsepower drag and road racing applications. Goopy Performance Stony Point, NY 10980 845-947-0007 Phone 845-947-0047 fax Www.GoopyPerformance.com
Old 02-14-2011, 02:17 PM   #1
GoopyPerformance
Rotary parts manufacture
Goopy Performance ROTOR HOUSING REFURBISHING Services
Cost Effective Solution for these Economic Times ...
10-15% of the Cost of Replacement!
Updated Pricing
In today's economy everyone is looking for cost effective solutions and
the best way to get maximum performance for their dollar spent. That
was Goopy
Performance's thinking and objective behind our ROTOR HOUSING
REFURBISHING
service.
When any of us consider rebuilding a rotary engine, the condition of the
housings is a key factor. Up until now the options have been either
1.) use your housings as is, or 2.) buy new housings at the cost of
approximately $1,300 per pair or more. If porting had already been
done on
these housings, the real cost of replacement could include an additional
$200 to $400.
Goopy Performance's Refurbishing process provides a solution at
approximately 10% to 15% of
the cost of replacement. While not providing a 100% new surface for
your apex seals to break into
a "like new" surface in the very high 90 percentile (95-99%) is
provided in most cases.
Here is an attempt to answer most of the questions that have been
posted on various forums recently ...
1. We are NOT resurfacing or adding new material to the housings. We are
refurbishing or refreshing the existing hard chrome surface.
2. NO we do not have data or photos showing results after 20,000 miles.
However, we have had very high HP racers running our refurbished
housings
with our Goopy Performance Apex Seals for a full race season (40-50+
passes) while maintaining very high compression and no housing damage
of any kind.
3. NEW PRICING INFORMATION
As of November 1, 2011 (11-1-11) the standard PRICING is $300 US per
pair of housings
with the customer paying for the shipping to and from Goopy Performance.
This price includes media blasting of the housings to achieve the
"like new" appearance
as seen in Judge Ito's photos.
Please do not send dirty, greasy housings or there will be an
additional $25 “Cleaning Fee”.
4. $200 US per pair PRICING ...
will be honored when a minimum purchase of one set of
accompanies the order for EACH PAIR OF HOUSINGS that are to be
refurbished.
You will also have the option to order other Goopy Performance parts
or kits valued at $350 US or more.
5. Our refurbishing process greatly improves all of the conditions
mentioned in various different posts ... scratches, scoring, gauling and
flaking edges. Our process provides a relatively flat, uniform, matte
housing surface for your new seals to break-in to. The true measure
of the
effectiveness of the process is the compression numbers that are
achieved
when your engine is rebuilt, not just how the housings look. Our
experience with our refurbishing along with using our Goopy Performance
Apex Seals is that we have consistently produced compression readings at
or above factory stock specifications. Also refer to Judge Ito’s
experience after 3 years of having compression numbers of 125-128 psi.
6. The SIDE PIECE on the Goopy Performance Apex Seals does not come to
such a sharp point at the housing surface like if does on many other
apex
seal designs. We believe this design improvement yields less wear and
deterioration at the housing edges that cause potential compression
leakage.
7. In most cases the amount of material removed to achieve these “like
new” results is relatively insignificant. In our experience,
utilizing our
Goopy Performance Apex Seals which are manufactured at the same
height as
OEM seals, we have not experienced any issues due to the removal of this
minimal amount of material.
8. If you are unsure if your housings are candidates for our
refurbishing
process please send photos and description to info@goopyperformance.com
before expending your time and resources on packing and shipping.
However, if we receive housings that we consider to be beyond repair
with
our process, we will notify you before any work is done.
9. We provide our housing refurbishing service on all models and
vintages of rotor
housings.
Please email to info@goopyperformance.com if we have not addressed
all of
your earlier questions or new ones have come up in the meantime.
GoopyPerformance is offline   Reply With Quote
Old 02-14-2011, 02:23 PM   #2
GoopyPerformance
A few pictures.
Old 11-09-2011, 01:38 AM   #3
1Revvin7
Turblown Engineering
1Revvin7 is on a distinguished road
I finally got to do a compression test on a customers car @ 5000 miles with the housing service and standard apex seals. Perfect compression results. Couldn't be happier. We also have another turbo Rx-7 that has this same combo with over 15k street miles. These seals are also in our shop car's bridge engine which pulls 14" of vacuum at idle.. Pretty good for bridge..
Rx-7 Turbo Kits, Engine Building, and Parts
www.turblown.net
1Revvin7 is offline   Reply With Quote
Old 03-15-2012, 09:52 PM   #4
kenspec
kenspec is on a distinguished road
Hey Goopy, Its Ken from Canada, My housings finally got to you guys! Keep me updated on the progress!
kenspec is offline   Reply With Quote
Old 04-04-2012, 09:29 PM   #5
WankelPwr93
WankelPwr93's Avatar
WankelPwr93 is on a distinguished road
I'll see you on Monday to pick up my housings,seals,etc.
Top of the line work for a fraction of the cost of housings.
A.G
WankelPwr93 is offline   Reply With Quote
Old 04-04-2012, 09:54 PM   #6
rxspeed7
The fan hit the shit!
rxspeed7's Avatar
rxspeed7 is on a distinguished road
You guys are just re-finihsing the factory steel insert correct? Like a housing with moderate chrome flake you can't help that with your service correct? I have quite a few housings down here at the shop that i would love to get re-done if you can. Thanks
Zack@ GNS racing
87 TII= High comp 13b-re,S360,Link G4 RX
I suppose you could orally BDC or even anally BDC someone? or be BDC'd in those two ways also
Many ways you can get BDC'd
rxspeed7 is offline   Reply With Quote
Old 04-05-2012, 07:18 AM   #7
GoopyPerformance
Zack@ GNS racing
The best method to evaluate a housing is email us a few images of each housing..We will asses them and go from there.
To all who have used our parts or services thank you for all the kind words & referrals.
Old 04-14-2012, 11:20 PM   #8
Dannobre
Dannobre is on a distinguished road
Glad to see you being more civil on here
I hope that you will get an answer from them and this gets straightened out...
BTW...from the Goopy invoice....
But seek first his kingdom and his righteousness, and all these things will be given to you as well.
I have a good feeling that things will get worked out if you are being honest and upfront
Dannobre is offline   Reply With Quote
Old 08-29-2013, 09:12 PM   #9
Kman Art
The Converted
Kman Art's Avatar
Kman Art is on a distinguished road
Rotor housings on their way back home. Will post before n after photos upon their arrival.
Very excited!!!
Kman Art is offline   Reply With Quote
Old 08-29-2013, 09:25 PM   #10
chibikougan
chibikougan's Avatar
Think it will buff out?
Old 09-29-2013, 09:14 AM   #11
Kman Art
The Converted
Kman Art's Avatar
Here are the before n after photos of the rotor housings...
Before
And After
Old 09-29-2013, 05:32 PM   #12
banzaitoyota
banzaitoyota is on a distinguished road
Looks good. Waiting to see how your build turns out
My deuce
banzaitoyota is offline   Reply With Quote
Old 09-30-2013, 12:04 PM   #13
Kman Art
The Converted
Kman Art's Avatar
Using Goopy seals too so I'm lookin forward to firing it up soon.
Old 10-30-2013, 12:21 PM   #14
GoopyPerformance
Post some pics and updates..
Old 10-30-2013, 01:35 PM   #15
Kman Art
The Converted
Kman Art's Avatar
Started the car last night, but it's still on the lift. Had the car painted with a company design that took a while, plus several other things were all done at the same time. Might have to start a build/performance thread on here to cover it all.
This is a pic with the engine back in. Got hooked on powder coating but only had the UIM and LIM plus my calipers done so far.
