Old 10-14-2010, 05:57 AM   #1
Grappler
Grappler is on a distinguished road
Fuel Hardline Diameter?
Looking to get some adapters to go from my hardlines to -6 an (currently ghetto rigged with clamps)
is the Hardline 3/8ths or 5/16ths?
Something like this correct?
http://www.summitracing.com/parts/EAR-165056ERL/
http://www.summitracing.com/parts/RUS-639200/
Thanks
Grappler is offline   Reply With Quote
Old 10-14-2010, 10:57 AM   #2
It's actually metric like 8.0mm or 8.5mm?
It's close enough to 5/16" SAE...
Old 10-14-2010, 02:34 PM   #3
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Hmm, so using 3/8" ID rubber hose is incorrect?
Old 10-14-2010, 06:30 PM   #4
On stock hard fuel lines?
No, they offer 5/16" size - it's a pretty typical size if you can't believe it.
Make sure it's FUEL INJECTION rated.
Old 10-14-2010, 06:38 PM   #5
Grappler
Alright thanks RETed I will double check and make sure about the pressure ratings
Old 10-14-2010, 07:08 PM   #6
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
LunchboxCritter is on a distinguished road
5/16" ID and about 6' will get you from hard line to fuel rail, and fuel filter to fuel rail.
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn.
DO NOT TRY THIS AT HOME!!!
LunchboxCritter is offline   Reply With Quote
Old 10-14-2010, 10:22 PM   #7
NoDOHC
NoDOHC's Avatar
I would recommend hard lines over the engine. If you use hose, make sure and tie it fast to something so it doesn't rub and wear through.
Old 10-15-2010, 07:24 AM   #8
FC Zach
FC Zach's Avatar
Thanks
The first link is what I would use. Thanks for bringing this up, I need one of these too. The second link wouldn't work for you, 3/8 is too large.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
