I began this project to clean up my window regulators in an attempt to speed them up a bit, like all projects it has grown exponentially
.I got my inspiration from this thread over on 7club. http://www.rx7club.com/showthread.php?t=910274 There are a couple notes I would like to make: 1. When removing the passenger door panel remember to pop out the window switch and remove the philips head screw. 2. I elected not to spray silicon lubricant down the run channels as I figure over time that will just collect dust and compound the problem. I also elected not to remove the run channels so for now I have left them as is. 3. To operate the passenger window both the driver's and passenger's window switches must be hooked up. As of now, I have only done the passenger window regulator, I expect the driver's side to be much the same. Now, for the rest of the project! I will be addressing several issues: 1. Broken interior passenger door handle 2. Poor looking 93 plastics on both doors 3. Dirty interior door panels 4. Broken/Cracked mounting studs on door plastics 5. Stripped studs on exterior door handles I have begun this process on the passenger side and am verifying my methods to ensure that I don't pass along any incorrect information. I will post up some details as I go and will go more in depth when I tackle the driver's side.
Proud owner of a base 1993 Montego Blue FD. PFC, RB single tip, Koyo Radiator, KDR rebuilt motor, polished OEM front strut bar, FEED replica sideskirts, OEM 99 spec rear spoiler, SuperPro Bushings Many thanks to Dave at KDR for sparking my rotor addiction. |
Broken Stud Repair
**Full-size pictures available by clicking on the thumbnails**
Repairing broken studs. Here is the culprit: DSCF4040.jpg You will need a nylon bushing (3/8" OD, 1/2" length, ID less than 9/32") found at your local hardware store. OD - outer diameter ID - inner diameter You will also need some Plast-Aid, more about that in the next post. Step 1: Drill the nylon bushing to 9/32" ID. This will fit nicely over the broken stud. DSCF4041.jpg Step 2: We want to cut two slits in the nylon bushing so that it will fit down on the stud around the four existing plastic reinforcement tabs as shown in the following picture. DSCF4044.jpg To do this use a dremel tool with cutoff wheel attached. Cut the slits to a depth of 1/4," this will leave 1/4" above the plastic reinforcement tabs and make it flush with the foam on the back of the door panel when finally mounted. DSCF4043.jpg Step 3: Enlarge the mounting hole for the stud in the door panel to 3/8" using a 3/8" drill bit. DSCF4046.jpg Instructions continued in the next post.
Proud owner of a base 1993 Montego Blue FD. PFC, RB single tip, Koyo Radiator, KDR rebuilt motor, polished OEM front strut bar, FEED replica sideskirts, OEM 99 spec rear spoiler, SuperPro Bushings Many thanks to Dave at KDR for sparking my rotor addiction. Last edited by bbade; 07-02-2010 at 02:47 PM. |
Broken Stud Repair
Step 4: Test fit the plastic piece to ensure proper fitment and alignment. Make sure that the nylon bushing is flush with the back of the door panel and make sure that the plastic piece lines up correctly.
DSCF4047.jpg DSCF4048.jpg Plast-Aid http://www.plast-aid.com/ Credit goes to 'nashman69g' on 7club for experimenting with this stuff, it is actually how I found it. Some great information and tips on using it can be found in this thread on 7club http://www.rx7club.com/showthread.ph...plastic+repair. DSCF4050.jpg Step 5: Clean the nylon bushing and broken stud with acetone. Be cautious with the acetone as it can soften/melt the plastic if left to sit on the plastic. I put some acetone on a rag and wiped everything down, allow it to evaporate. Step 6: Put some Plast-Aid on the inside of the nylon bushing and then press it down on the broken stud. Fill the nylon bushing with Plast-Aid, bringing it level with the top of the bushing. Liberally spread Plast-Aid around the bottom of the nylon bushing (the area with the slits) to bond it with the plastic reinforcement tabs. Avoid getting Plast-Aid on the outer area of the bushing that will go through the hole in the door panel so that you don't need to trim it down later. DSCF4052.jpg DSCF4053.jpg Allow the Plast-Aid to set up, it should not take long at all. The stud should now be ready to drill and tap, I will post information on this step when I get to it, I may upgrade the fasteners in the process.
Proud owner of a base 1993 Montego Blue FD. PFC, RB single tip, Koyo Radiator, KDR rebuilt motor, polished OEM front strut bar, FEED replica sideskirts, OEM 99 spec rear spoiler, SuperPro Bushings Many thanks to Dave at KDR for sparking my rotor addiction. Last edited by bbade; 07-02-2010 at 02:52 PM. |
Cracked Stud Repair
Cracked Stud Repair:
The majority of mounting studs on my passenger side interior plastic were cracked, so to prevent them from breaking completely I reinforced them with Plast-Aid. Hopefully this will prevent further cracking, if not I will have to go back in and repair them with a nylon bushing per my last post. The procedure is simple, clean with acetone, and spread Plast-Aid over the crack and surrounding area. The first picture shows the crack highlighted with silver sharpie. The second picture shows the stud reinforced with Plast-Aid. DSCF4054.jpg DSCF4055.jpg
Door Panel Cleaning
Door Panel Cleaning:
Fortunately the door panels were not too dirty, but I figured I would give them a good cleaning while they are out. We will need: Simple Green Bucket Sponge Q-Tips Vinyl Cleaner/Protectant Step 1: Mix up a cleaning solution in your bucket using Simple Green and some water, dilute to your liking. DSCF4064.jpg Step 2: Clean the panel using the sponge, use the Q-Tips for tight areas. DSCF4065.jpg Step 3: Rinse the panel off well using a hose, then dry it off with a soft towel. DSCF4067.jpg Step 4: Use a vinyl cleaner/protectant on the door panel to finish everything off and ensure that it stays nice. I used this stuff from Meguiar's. DSCF4087.jpg While cleaning I noticed that the ventilation duct on the back of the door would not line up correctly. I took it off and drilled some new holes to hold it in place correctly. Not sure what size bit I used, just grab one large enough for the mounting screw to fit through. DSCF4066.jpg
Proud owner of a base 1993 Montego Blue FD. PFC, RB single tip, Koyo Radiator, KDR rebuilt motor, polished OEM front strut bar, FEED replica sideskirts, OEM 99 spec rear spoiler, SuperPro Bushings Many thanks to Dave at KDR for sparking my rotor addiction. Last edited by bbade; 07-04-2010 at 12:50 PM. |
Passenger Door Handle Repair
Passenger Door Handle Repair:
Now for the infamous door handle, mine was broken by an excited passenger last summer at a track day . There are several documented fixes for this handle, but I didn't find one that quite fit my liking.Step 1: Clean the break area. Trim back any overhanging foam tape. It is also a good idea to trim down the break so that the Plast-Aid can really penetrate and get a good bond. I didn't get a good picture of this step, but here is a picture of the break I am working with. DSCF4057.jpg Step 2: Attach the two broken handle pieces to the main plastic piece; there will be two screws on the upper portion and two screws on the lower portion of the handle. Once all the plastics are together, attach them to the door panel as though you were reassembling everything; there are 6 or 7 screws. I forgot to take a picture of this step, but y'all know what the door panel looks like assembled. Step 3: Make sure all the plastic pieces are aligned satisfactorily. Then tape some aluminum foil around the back side of the break (looking at the door panel), this is to prevent Plast-Aid from leaking through. Mask off the area around the window switch hole and place a towel or rag over the door panel to serve as a drop cloth. You want to be very careful not to drip Plast-Aid on your door panel. DSCF4070.jpg DSCF4069.jpg
Viable Fossil
Very nice. Thanks for taking the time. I've got a few of those broken studs myself. So far they haven't been an issue, but I smell a winter project.
I've never worked with the Plast-aid. In the final step or any of the steps using the Plast-aid, do you need to sand the metal and/or plastic surfaces to help adhesion?
Jim VR R1 FD |
Hey guys, sorry for the huge delay. I just returned from an unexpected week-long trip to Indiana. I managed to finish the passenger side prior to leaving so I will post updates asap.
Signal - I did no sanding on the plastic or metal and had no issues with adhesion, this stuff sticks! I had attempted to make a mold out of wood soaked in grease similar to something they show on the Plast-Aid website and it even stuck to that. Cleaning the bonding surfaces well with acetone should be all that you need to do to ensure a good bond; however, I would not count on it bonding with the metal, I laid down a nice thick coat encasing the metal reinforcement so I was counting on it bonding to the plastic itself.
#9 |
Step 11: Paint! We are just about finished. Clean the handle well with soap and water to remove any sanding dust or grease. I used Duplicolor Adhesion Promoter and Duplicolor Bumper Coating (I think it comes in several colors so make sure to get black). Autozone no longer carries Duplicolor, I lucked out and got the last cans of the stuff, but I imagine it isn't that hard to find elsewhere. Follow the instructions on the can, I laid down 3 coats of adhesion promoter at 2-3 minute intervals. Wait about 10 minutes then lay down 2 coats of the bumper coating at 3-5 minute intervals. As always with spray paint, several light coats are better than one heavy coat.
DSCF4090.jpg DSCF4095.jpg DSCF4097.jpg You can tell I could have laid the Plast-Aid in a little thicker in some areas, but I really wasn't concerned as this portion of the handle is not visible when the door panel is assembled. Here it is assembled, the main plastic portion has also been refinished with the bumper coating. DSCF4099.jpg Here is a close shot to compare the bumper coating with the 93 finish on the window switch. I elected not to refinish the window switch as I didn't want paint getting into the internals and on the contacts causing further headaches. The bumper coating has a nice texture to it, I was extremely pleased with the way it came out. DSCF4101.jpg
#10 |
Rep Power: 20 ![]() |
Looks great!
I just fixed all my passenger door handle problems several months ago. I don't remember having to use a metal piece to attach the bottom of the handle to the other piece though...? I think the screw was just loose or missing or something, I don't remember for sure. I'll have to look at it the next time I take it apart. It's solid as hell though. I let people actually use the handle to close the door now LOL. I had a problem with the mounts on the long thin part too, the one holding the very back of it down, close to the striker end of the door. I didn't know you could get those nylon bushings though. I just JB welded a bolt on there because my mount was completely gone and I used a nut on it. Actually I think I used two nuts, one as a locknut, and tightened them against each other. I also had a problem with the mount right behind the window switch. I JB welded that back together too. So far it's been holding up pretty well, knock on wood lol. I didn't do any cleaning of window runners or regulator though, now I kinda wish I had done that while I was in there, didn't even cross my mind. |
#11 | |
The metal was not used to attach the handle to the door or plastics, it was used to reinforce the two halves of the handle itself. My handle was completely broken in two which is the only reason it was necessary to do the repair. Good idea with the bolt; nice, simple, efficient fix. I have since discovered that Plast-Aid does not form a chemical bond with nylon which is unfortunate, but I was able to get more than enough in there on the last stud to form a mechanical bond. I am going to take a new approach when repairing the driver's side plastics.
#12 |
Okay guys, some updates will be coming next week, ran into some problems on the drivers side plastics. One stud was broken off at the base and has given me a real headache, I have gone through two attempted repairs so far and am finally going to do it the right way this time.
My first attempt was to take the broken stud and reattach it with the Plast-Aid. While attempting to glue the stud and plastic together everything shifted and would not line up correctly with the door panel. Also, I decided it was a half-assed way of doing it so on to attempt two. Attempt two started with a nylon bushing similar to the stud repair outlined above. Everything went together without a hitch and appeared to be fine, but turns out Plast-Aid does not form a chemical bond with nylon. When I repaired the last stud I used more than enough Plast-Aid to form a mechanical bond; however, there was no way to get that much on this stud. I am not worried about the last stud I repaired coming apart because of this revelation, but I realized I needed to take a new approach. This third fix will work as I am done playing around . I have ordered ABS rod from McMaster Carr and am going to make one heck of a robust stud. I will outline the process and post it here sometime next week.
#13 | |
The ABS rod worked out very well. Using a lathe I machined the rod down to the diameter of the original stud or just a bit thicker. I left a nice base at the bottom for ease of bonding. DSCF4140.jpg Make sure you cleanup the bonding area (you can see the nylon attempt mentioned earlier). DSCF4139.jpg Put some Plast-Aid under the post, then reinstall the plastic piece in the door panel to line everything up. After this initial bond sets up reinforce with additional Plast-Aid. DSCF4144.jpg In summary I am more than happy with the result. Hope this helps, happy new year!
#14 |
Oh OK, gotcha.
Yeah so far the bolt has been holding up, but I'm not sure it's had enough abuse yet to say it's really been tested. I'm still kinda iffy on the handle being used to shut the door haha. Good luck with this next round of fixing, hopefully you won't have to repeat it. I get very annoyed having to do things over and over haha. |
#15 |
I'm about to do a similar fix on my busted passenger handle, but I'm curious if anybody thinks JB Weld or epoxy putty like this stuff would do just as good? I've got a LOT of busted plastic to repair.
Thanks.
My sex machines: -'94 Rx7 R2, Pettit TKT: SOLD -'85 Rx7 GSL-SE: SOLD -'90 Rx7 GTU, stock: SOLD -'93 Rx7 base: my current baby |
| Tags |
| door handle, door panel, platic repair, window regulator |
