Old 06-24-2010, 10:21 PM   #1
gkarmadi
water jacket mod?!!
gkarmadi's Avatar
gkarmadi is on a distinguished road
external wastegate line/hose
what's a good external wastegate line/hose to use?? I am sicken tired replacing my silicone hose, it keeps melting. If using ss line, what size should i get/use??
thanks in advance..
86GXL
BSC streetport + TD07@13psi
gkarmadi is offline   Reply With Quote
Old 06-25-2010, 12:14 AM   #2
GorillaRE
Outside the "box"......
GorillaRE's Avatar
GorillaRE is on a distinguished road
thanks in advance..
-4 stainless. And ALWAYS protect any and all lines, wires etc. near the turbo/exhaust with this > http://www.summitracing.com/parts/DEI-010472/
-J
" Life is full of trials and tribulations, misery is optional."
-Mark D. White RIP man, we love you...
We specialize in Rotary, Japanese, European and Exotic performance forced induction cars. We also custom build 3/4 multi-rotor engine setups for the street or track.
We are the only authorized Fujita Engineering dealer in the USA. Call for authentic FEED parts. Call for ECU tuning.
http://www.facebook.com/pages/Gorilla-Race-Engineering/43530496660
GorillaRE is offline   Reply With Quote
Old 06-25-2010, 12:15 AM   #3
If you're burning silicone hoses, you think SS lines is going to be any better?
Most "SS hose" is just a rubber hose wrapped with a SS sleeve.
The rubber isn't more heat resistant than silicone (hose) is?
Granted, the SS sleeve does reject some heat, but SS has this bad property of absorbing and keeping heat in.
I'd really look into trying to rerouting your hoses to see if you can do better.
Next, I would look into hose coverings like those fire sleeves for spark plug wires?
http://www.heatshieldproducts.com/red-hot_sleeve.php
Look, even they use silicone as a material on their fire sleeves.
http://www.pitstopusa.com/SearchResu...ategoryID=2429
Check out their inventory...
Old 06-25-2010, 07:58 AM   #4
classicauto
crash auto?fix auto
classicauto's Avatar
+1
I had SS lines on my old turbo setup. Greddy typeR gate......I was trying to diagonsea boost problem that was acting like a boost leak. Ended up being a pin hole burnt in the SS line.
Fire sleeving or other protective wrap is the best insurance. Or hard line.
Old 06-26-2010, 08:04 PM   #5
gkarmadi
water jacket mod?!!
gkarmadi's Avatar
So, what's a good (or highly recomended) hose to use for wastegate?
Btw, thanks for all the input..
86GXL
Old 06-27-2010, 12:10 AM   #6
-3 SS hardline. Think brake line
Old 06-27-2010, 01:44 PM   #7
like, with brake line fittings as well? Sick!
Old 06-27-2010, 08:40 PM   #8
Yeah, pretty much.
Old 06-27-2010, 08:59 PM   #9
Just stop pussy-footin' around and hard line it already. I'm on a hard line trip. Hard lining my coolant overflow, my scavenge pump and probably a load of everything else Yes... I like torture and pain.
Old 06-27-2010, 09:06 PM   #10
Nah, you just like stroking hard lines
The coolant system work that you posted up looks damn sexy.
Old 06-27-2010, 09:15 PM   #11
It'll look drop dead gorgeous when I put in that order for the re-circ tank I'm thinking I may adjust the design a little bit which will lend itself to a more compact design... though you may not like the idea
