| Interior, Stereo, Body kits, etc... Place where you could talk about car care, body kits, painting your car, Carbon Fiber, Thumping Stereo, etc.. |
Rotorhead
Body rust and how to remove it.
Im restoring a 90 gtus and it has rust in various locations around the body. I'd like to hear what the folks of RRC recommend at how to remove it or neutralize it. I know this car has body damage. I plan on painting this car sometime next month if Junpower isn't busy. I will be helping him with the prep and body work and he does the paint. The pics are in my album at http://rotarycarclub.com/rotary_foru...hp?albumid=147
Currently running: 90 GTUs converted to S5 TurboII. Track car. 90 N/A GTUs.. Running project car 89 N/A GTUs in Black #2 10/6/18 Blown coolant seal undergoing rebuild and restomod. |
Can't.Make.Up.My.Mind.
where is the rust? there is some stuff you can use that will convert the rust so it doesnt spread. you can get it in a spray can, this stuff usually takes 2 light coats if i remember correctly. or there is a black liquid that comes in a small bottle that you can brush on. DO NOT GET IT ON YOUR PAINT. you should be able to get both at your local paint supply store. national coatings, H-O, etc.
Depending on where the rust is though you might be just as well off to cut it out and weld in a patch if youre handy.
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" |
