remove the oil metering pump block off
For those who remove the oil metering pump and the injectors I have made a 3/16 thick steel block off plate and a gasket .The stock O-ring is expensive and the gasket will not harden with the heat The plate is slightly larger than the omp foot print so there is more material around the bolt holes .I use flanged bolts to plug the injector holes with a sealing washer under the flange .I cut the OD of the flange down to clear the locating nib on the housing and cut the length to fit . I could not buy the correct length. The cost has has been set at $20 plus shipping .
Strange picture but nice kit for sure .
douche bag
LOL the pic look's like one of those that you put to your face and pull back slowly with and then you see the ( real ) pic.. very clean looking kit though.. and a great price to boot. i shall be picking one of these up soon from you.
- chris xbox live - GraveConditions R.I.P paul gray - # 2 |
I like these better then Bonzai's BOP. Please let me know if you do a run in aluminum.
I have several ready to ship with a gasket ,mounting bolts and the flanged bolts and crush washers to plug the oil injecter holes.
Nice kit that no one needs when they said build it and they will come .
Rep Power: 20 ![]() |
If you talk to Jess, ask him if he deals with issues such as this. He could give you many examples which is one reason why he's hesitant to make anything anymore.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
I made these and the ones who said they needed them did not buy.was the price to high,I think not any way I have several to sell .
