Old 02-17-2010, 11:45 PM   #1
Pulled Turbo, have questions
I pulled the turbo because I had an exhaust leak on one rotor and assumed it was the block-to-manifold or block-to-turbo gasket. However, the 4th picture shows what was causing the leak. A EGT hole! I can't believe I didn't see it taking off the turbo but I was too worried about not breaking studs to notice.
Other than an EGT sensor itself, do I use a steel or brass NPT plug to stop the leak?
It is a Knightsport front housing with stock hotside. The wastegate is unported as far as I can tell. It has had part of the front housing ground down slightly to fit next to the LIM. Can anyone tell me what to expect out of the turbo as a whole?
I noticed a deposit that seams to be leaking out of it (see pic 5). Can anyone tell me what this is and if it is a symptom of a problem? Coolant?
If it has problems I want to take care of them before it goes back on the motor.
Thanks!
Old 02-18-2010, 01:41 AM   #2
I've used steel and brass and either or will work.
The brass is more forgiving and should be easier to remove if you need to at a later date.
The metal doesn't get hot enough to melt brass.
Old 02-18-2010, 11:13 AM   #3
Thanks Ted, I'll go with brass.
Old 02-18-2010, 02:18 PM   #4
Anyone have any ideas as to the white deposit on the hotside? I'll try to take a better pic tonight.
Old 02-18-2010, 02:46 PM   #5
Bryan@BNR
Bryan@BNR is on a distinguished road
You have a coolant leak.
Bryan@BNR is offline   Reply With Quote
Old 02-18-2010, 02:53 PM   #6
Ok. I have never rebuilt a turbo. What would it take to get rebuilt? Can I do this myself?
What would it cost to send it to you and be rebuilt?
Thanks btw.
Old 02-24-2010, 10:26 PM   #7
Ender
rotors excite me
Ender's Avatar
No, you can't, not properly. They need very precise balancing. I disassembled my turbo once and reassembled it after realizing I couldn't do any good with it apart anyway. I tried very, VERY carefully to put it together EXFUCKINGACTLY like it came apart and it would appear I got very, VERY lucky. I will never do that again after hearing how easily a turbo can become imbalanced and then tear itself apart.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 02-25-2010, 08:50 PM   #8
1Revvin7
Turblown Engineering
1Revvin7 is on a distinguished road
Coolant leak is probably coming from one of the coolant hardlines. Chances are just a crush washer needs to be replaced. Look for pitting on the hardline and chra though.
1Revvin7 is offline   Reply With Quote
Old 02-24-2010, 07:01 PM   #9
Hi-res pics of the leak.
