Old 10-11-2009, 09:24 PM   #1
Jeff20B
Jeff20B's Avatar
Are aftermarket engine mounts available yet?
My bro's RX-8 has just started to have the dreaded vibration at idle and shifts are kinda clunky. First thing on my mind is motor mounts! I did some research on the RX-8 club forum and the Mazdatrix website. Seems only OEM and upgraded OEM are available, with a heat shielded bracket.
I'm not interested in OEM. I've had great success in 1st gens and older rotary Mazdas with competition mounts (40% stiffer than stock) and hockey pucks (60% or more stiffer).
Not interested in hard mounts either. I want something that drives like the good old competition mounts for a 1st gen. Some give, but noticeably stiffer than stock. Does anyone make aftermarket mounts for the RX-8 yet?
Old 10-24-2009, 02:49 PM   #2
I8U
KONI Challenge Crew
I8U's Avatar
I8U is on a distinguished road
Short answer, NO. Sorry...there are solid mounts out there but they tend to cause the engine support brackets to fail and break easier. I know some have modded the stock mounts with some kind of shoring compound but that's about it.
04 TiGray RX8 MT, LS2 coil setup, 3" midpipe, HKS Hi-power 3" exhaust, TEIN S-Techs, Hotchkis Adj F/R sways, K&N Typhoon V2, Steel braided brake lines, Redline drivetrain fluids, ATE Super Blue brake fluid, Cobalt XR2/GTS brake combo, MB Motorpsorts Weapons 18x9 +45 offset, 275/35's
I8U is offline   Reply With Quote
Old 10-25-2009, 01:10 PM   #3
Jeff20B
Jeff20B's Avatar
Looks like upgraded OEM is a possibility then. Thankyou!
Old 10-26-2009, 07:47 PM   #4
mazdamaniac
mazdamaniac's Avatar
mazdamaniac is on a distinguished road
There are a few ways to address the OEM mounts, but it depends on your goals.
I've filled a couple of sets with different urethanes which works fairly well, but increases the NVH considerably, even if the Shore is fairly soft.
I have an insert I'm bringing to market soon that will address a lot of the "floppyness", but its not the same thing as a solid mount.
mazdamaniac is offline   Reply With Quote
Old 10-27-2009, 11:41 AM   #5
Kane
All about the O2
Kane's Avatar
Kane is on a distinguished road
I have some prototype urethane mounts... but they are not available for retail per se; but again they are basically refilled stock mounts.
My 2007 Turbocharged RX8
Kane is offline   Reply With Quote
Old 10-27-2009, 10:36 PM   #6
I8U
KONI Challenge Crew
I8U's Avatar
I look forward to seeing what you're gonna throw out there Jeff.
