Old 03-19-2009, 08:02 PM   #1
AHarada
Slow window.
If I don't touch my window for a while, the speed is normal and the window operates beautifully. But if I've operated it recently and try it again, it is really really slow and sounds like the motor is straining. Does this sound like the motor is going bad? I pulled out the regulator unit and cleaned and lubed it and this did not help. Is there any way to test this to make sure it's the motor?
Old 03-19-2009, 08:54 PM   #2
zonblitz
zonblitz's Avatar
zonblitz is on a distinguished road
sounds like you need a new car.
Kenny
If you need a website, or know anyone who does, look me up: www.efiniconsulting.com
zonblitz is offline   Reply With Quote
Old 03-19-2009, 11:58 PM   #3
AHarada
Maybe I'll just rebuild and port the window motor.
Old 03-20-2009, 12:15 PM   #4
FD3sAutobot
FD3sAutobot's Avatar
FD3sAutobot is on a distinguished road
Alternator going bad maybe?
FD3sAutobot is offline   Reply With Quote
Old 03-20-2009, 03:54 PM   #5
AHarada
I have no other signs of a battery/alternator issue, and my PFC reads around 14V at idle. The driver's side works normally also so that's not the issue.
Old 03-20-2009, 04:42 PM   #6
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Do you notice a drop in voltage when it acts up? If so see if there is high amp draw.
Old 03-23-2009, 08:34 AM   #7
bbade
bbade's Avatar
I have a similar problem, also only on my passenger side window. If i try to operate both windows at once both sides really struggle.
Old 03-23-2009, 11:14 AM   #8
GreatShamanGT
GreatShamanGT is on a distinguished road
Have you tried cleaning the rails?
GreatShamanGT is offline   Reply With Quote
Old 03-23-2009, 07:20 PM   #9
MOBEONER
MOBEONER's Avatar
MOBEONER is on a distinguished road
all my rx7s have always been poor with the window speed..i would suggest cleaning and lubing the rails. also if you have not done the ground wire mod do so at this time it might help.
Hit em and run plumbing
MOBEONER is offline   Reply With Quote
Old 03-24-2009, 11:01 PM   #10
AHarada
I have already cleaned and lubes the rails, but it has not helped. Could you give some more info on the ground mod?
Old 03-26-2009, 08:01 PM   #11
MOBEONER
MOBEONER's Avatar
http://www.rotaryresurrection.com/3r...st_ground.html
Old 03-27-2009, 03:22 PM   #12
jkstill
jkstill is on a distinguished road
My 3rd gen (51k miles), a previously owned very low mileage 91 2nd gen vert, and a current low mileage 89 GXL all have slow windows.
They are just slow. They always sound like they are going to die, but get there eventually.
No alternator or battery problems with any of them.
jkstill is offline   Reply With Quote
