Old 02-12-2009, 06:43 PM   #1
need RX7
Clean S4 Nutswinger
need RX7's Avatar
WTF? starting, idle problems
So I finally got my FC running right and on the ground. I just tried to start it to pull out in the driveway and it won't crank. It makes a click sound, then some random buzzer starts going off and the tach climbs up to 3k (not cranking at all, keep in mind) The lights also go way dim when this happens. I just started it less than an hour ago to check the timing and it ran perfectly. I'm guessing something is shorted out somewhere, where should I check?
Agh, I swear this car has a mind of it's own. It knows how to build up my hopes then smash them to pieces... fucking bitch...
cranking, electrical problem, fffuuuu-, no start, starter
