Old 01-19-2009, 02:59 PM   #1
moremazda
shookmotorsports.com
moremazda is on a distinguished road
Help fund my addiction!
All prices are best offer and do not include 3% for pay pal.
Haltech E6X $600 shipped
comes with
GM water temp and clip
GM air temp and clip
GM tps, with clip (on harness) and bracket for the FC throttle body
FD boost sensor with pig tail (2 bar)
2 Marren 550cc injectors no clips
Wiring harness that should be replaced if you want the ECU in the stock location
the Bad
The AUX IN does not work and if you need the AUX IN to work the ECU will need to go to Haltech. If you can live with out the AUX IN the ECU functions just as a E6X should.
Blue Greddy turbo timer with official mad tyt3 JDM yo! instruction manual $60 shipped
Original Profec-B with blue case $270 shipped
Izuzu NPR shorty $100 shipped
Solid diff mount $40 shipped
Front 5-lug hubs, they will need new bearings $50 shipped
Turbo water pump housing, Has 3/8npt thread for the water temp sensor and the water return for the turbo is plugged $40 shipped
Brand new never used S5 turbo tranny cross member $75 shipped
S4 water pump w/ ~1000 miles $50 shipped
I'll post a picture in a little bit.
moremazda is offline   Reply With Quote
