Old 03-12-2009, 10:44 PM   #1
Guru Flywheel
So i have been toying with the idea of a Guru 4140 flywheel for sometime now. I prefer the natural aspiration routes as of late and one of the biggest places to free up some rotating weight is the flywheel. I have considered a few options but i have though about going above and beyond. Guru makes a flywheel spec'ed out below. Its very light, uses the 5.5 clutches which would make hi rpm operation a sound deal and would probably be the best thing possible if you wanted to go all out. Obviously its not the cheapest route costing about 800 or so for the flywheel (AUS dollars) and another 800 for the clutch setup (american dollars).
I dont know of anyone using one stateside, but i am curious on how it would operate and exactly the difference between it and the run of the mill light weight setups are.
GURU Racing has produced a 4140 Chrome Moly Lightweight Flywheel to suit 5.5" clutch assemblies. Lightweight flywheels increase throttle response and aide in overall vehicle performance.
Standard (TurboII)
44 lbs - Clutch assembly and flywheel
27lbs - flywheel
Guru 4140 Flywheel
16 lbs - clutch assembly and flywheel
10.1 lbs - flywheel
So not only providing a performance improvement product but adding a substantial safety factor with approximately 25% less inertia than a 7.25" clutch for improved acceleration.
Applications based on generation 2 & 3 (Series I-VI) turbo RX7's and are a direct bolt in without modification. The kit comes with thrust bearing and housing as well as gearbox thrust bearing support.
Technical Specifications:
Flywheel:
Flywheel currently delivered for the RX7 Turbo case transmissions
RX7 Generation 1-3 (Series I-VI)
Direct fitment within bell-housing with no modifications necessary
No ring gear as teeth directly cut onto flywheel
Flywheel heat treated and black oxidised
Clutch:
Suit AP, Tilton and Quarter Master (QM) 5.5" clutch assemblies
Delivered with custom thrust bearings & mount as well as gearbox thrust bearing slider nose
Material:
All component are precision manufactured
4140 Chrome Moly
Heat treated and black oxidised
Old 03-13-2009, 07:22 AM   #2
Flywheels this light + the fact that they are using the 5" disc from QM and Tilton implies race use only.
Don't even try to use them on the street...
Wait, let me qualify that...you gotta be crazy to use them on the street.
Old 03-13-2009, 09:25 AM   #3
RotaryProphet
Wait... you guys aren't crazy? Am I really the only one?
Old 03-13-2009, 09:28 AM   #4
i would almost want to see just how bad it would really be. Figure the twin disk setup is the low end clutch. Im not talking about a daily driver. I have seen plenty of Evos run triple disk 7.5 / 5.5 clutches and they drive on the "street"
Old 03-13-2009, 10:37 AM   #5
Boy, you're in for some loads of fun.
Old 03-13-2009, 12:20 PM   #6
for now im opting for a OS giken setup off Rob since its more practical, but someone has to be "that guy". Also might keep others from hassling me and wanting to drive it. Its really all up in the air since i have to figure out some cross compatibility if i opt for the T5. I know the 5.5" clutch setup can easily be found for the 1-1/8" 26 spline GM stuff. OS seems to have a clutch that should work too that was originally meant for the Holinger sequential transmissions. Hell, maybe ill just get both since im sure to have more than one car in due time anyway.
Old 07-03-2009, 01:23 PM   #7
cturbo28
cturbo28's Avatar
cturbo28 is on a distinguished road
The GURU set up looks interesting. I would be worried about replacement parts but that might not be an issue. What are the best sources to buy one?
cturbo28 is offline   Reply With Quote
Old 07-06-2009, 11:21 PM   #8
Black91n/a
Black91n/a is on a distinguished road
You can get organic disks in 7.25" that would be better for semi-street duty, as you'd gain more modulation over a 5.5" race disk. Another thing to consider, get a flywheel for an NA transmission and use an RX-4 or similiar bellhousing, as I'm told it'll bolt up to a TII transmission and works with the smaller NA flywheel size. Should work with whatever T5 adapter you'd have to use as well. The smaller the flywheel, the less the inertia for a given weight, also, it should be able to be lighter by being smaller.
Black91n/a is offline   Reply With Quote
