Old 10-31-2008, 12:36 AM   #1
hyperlitenerd
Captin Safety
hyperlitenerd's Avatar
hyperlitenerd is on a distinguished road
Check Engine, no power
Well I had a problem with the car today. Driving home, turning onto the expressway, I got a check engine light, and hit what felt like a fuel cut at 3k rpm, and a 2k limit in any gear but first. I limped it at 40 mph home. Nothing under the hood looked to be wrong, no fluids pouring out, all the hoses seemed to be attached. I checked the oil level, it was at about 1/2 way down the dipstick. I topped it off. I found out how to check the engine codes, and checked it against an online database for them. It showed up as a code 27, which is a metering oil pump. I drove it again after I topped it off with oil. I was able to get up in the revs, but the car was noticeably slower, and the boost was slow to build up.
The only other thing that is going on with the car is that some time I will some times get a squeaking, or squealing noise when I decelerate mostly in second gear. If it is doing this squealing noise, it will squeal will I am at a stand still and free rev the engine, usually around 3k rpm. I don't know if that give you any clues for the above problem, but it is intermittent at best.
If you have any thoughts, it would be greatly appreciated.
hyperlitenerd is offline   Reply With Quote
