Go Back   Rotary Car Club > Tech Discussion > RX-7 2nd Gen Specific (1986-92) > Archives
Archives All the stickies in one place
Old 06-12-2010, 04:02 AM   #1
RX8 Front cover mod for 13B and 13BT
I was talking to Higgi about my issues with the pulley boss and how I needed to remove the front cover to make sure the needle bearings were seated right before torquing the new pulley boss. Long-story short I needed a new gasket and he mentioned that the RX8 gasket was a better choice but it needed to be modified. Very easy.
Have to cut the sections that don't line up without damaging the crush ring (hotlinking pics isn't working anymore)
The info came from this site:
http://www.rotaryheads.com/modificat...asket_mod.html
1. the RX8 gasket is metal vs. the paper ones for the FC
2. The FC front cover gasket is $25 + $4.75 for the Water pump housing-to-block gasket vs. $16 for the RX8 gasket W/ waterpump gasket.
3. It should help with the common leaky front cover.
I'll post pics of it if you want but it's self-explanatory, plus the pics from the site in the site are clear enough
End results:
You can find the gaskets from Atkins:
http://atkinsrotary.com/store/catalo...p-1-c-800.html
Note that this also works for the REW.
