Old 08-16-2008, 06:24 PM   #1
Dzire
Dzire's Avatar
Dzire is on a distinguished road
Overheating
I have a 1988 TII and it just hit 250 degree's. I would like to ask how much damage I could have done to the motor? I am planing on pulling the motor out to do a rebuild. Thank you for all your help in this matter.
RX8 2004 GT
RX7 1988 TII
Dzire is offline   Reply With Quote
Old 08-16-2008, 07:35 PM   #2
BLKTOPTRVL
BLKTOPTRVL's Avatar
BLKTOPTRVL is on a distinguished road
I would imagine the range of damage could be from "none" to "a lot."
Does it really matter how much damage poeple think has been done when you will be pulling the motor out and examining it?
I overheated my motor years ago. It soldiered on for a number of years until I took it apart. When I did, I saw a lot of damage to the housings and to one plate. Was it all heat damage? Who knows? (I am sure someone does, but the point for me is that it doesn't really matter.)
Either way. I hope your damaage is mild and that you will get a thrill like I did when taking my engine apart. When I did so, all the things (parts, systems, reasons things do and don't work) started to make more sense.
...shoot a mother-humpin moose, eight days of the week...
BLKTOPTRVL is offline   Reply With Quote
Old 08-17-2008, 01:45 PM   #3
Ender
rotors excite me
Ender's Avatar
You can warp the irons, and if it gets severe enough you can probably bind seals and or open holes between the compression chambers and the coolant system, both of which can result in severe wear or catastrophic engine failure. Try not to overheat these, it can be evil to them.
Since you overheated it, when you examine your irons and housings make sure you check carefully for overall flatness.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 08-25-2008, 03:39 PM   #4
JunpoweR
JunpoweR is an unknown quantity at this point
To all of the above replies!
Most likely you will have blown cooling seals to start with.
How come you overheated?
Low on coolant or just racing your motor for a long time?
Check your cooling system for bubbles and if you see any milky-ness or foam u got blown cooling jacket seals.
Since your rebuilding it shouldn't be a problem if your motoris still running but you might hav to replace a front or center iron. The seat fo the cooling seals are very thin in some areas causing them to crack and become unusable.
--^v--JunpoweR--^v--
"90 GTUs Crystal White *GT35 WB TA Project*
"90 GTUs Brilliant Black *Restoration*
1984 GSL-SE *Daily*
JunpoweR is offline   Reply With Quote
Old 08-26-2008, 06:45 AM   #5
classicauto
crash auto?fix auto
classicauto's Avatar
But before you rebuild. Determine why the car overheated as suggested. Otherwise you'll end up in the same boat.
