Go Back   Rotary Car Club > Classifieds > 3rd Gen Classified > 3rd Gen RX-7 Cars For Sale
3rd Gen RX-7 Cars For Sale Buy or Sell your Car only!! No Parts!
Old 05-23-2008, 04:05 PM   #1
rob20rx7
rob20rx7 is on a distinguished road
Thumbs up 1993 Extremely Modified Mazda RX-7 ONE OF A KIND (pics inside)
Ive come to the point of too many toys. need to start selling. this is not your regular daily driver. and might i add.... Massive Power with Cold A/C
Engine
.Street Ported intake and exhaust 13B-REW
.Low compression CLR Rotating assembly
·Lightened, Port Phased, High RPM Clearance, 3mm Apex Mod. And Bearing Journal Modification
·Engine was built by CLR Motorsports in December 2004 and just refreshed in March 2007
·MSD 10mm Pro Heat Wires with Shields
·Custom FD Alternator with Unorthodox pulley
·Unorthodox Under-drive Pulley
·Greddy Water pump Pulley
·Adel Wiggins 3 inch clamp
·Ground Zero Lower intake manifold (Extrude Honed and ported)
·OEM Upper intake manifold (Extrude Honed and ported)
·Greddy Aluminum Intake Elbow Power Coated Wrinkle red
·Custom 3 inch aluminum Intercooler Pipes Powder Coated Wrinkle Red
·Tial Blow-off valve
·Large Original HKS Inter-cooler 24x12
·T-72 / P turbine wheel / .96 Housing / T4 Turbo
·Custom 2 inch exhaust manifold
·Tial Waste gate
·3 inch down pipe with center section Including V-Band Clamps Ceramic Coated and wrapped
·HKS Super Dragger 3 inch exhaust
·Exeedy Twin Disk Clutch and flywheel set-up
·Haltech E6K ECU
·Dyno Numbers 516 RWHP / 405 Torque at 7800 RPM
Fuel System
·Custom Twin Walbro Fuel Pump Set-up
·-8 EFI Fuel Filter
·-8 aluminum fuel feed line
·-6 aluminum fuel return line
·SX Performance EFI Fuel pressure regulator
·Top Feed 850cc Primary, 1600cc Secondary
Engine compartment
·Custom 4 inch intake with large diameter K&N cone Filter
·SMC Alcohol Injection
·MSD 6a Ignition
·Custom 3 inch Griffin Track Radiator
·Flex-a-lite slimline electric fans
·Earls 16 row water Pre-cooler Modification for Track racing
·Earls 25 Row Oil Cooler
·High efficiency A/C Condenser
·NTX Intercooler Spray bar set-up with 10lbs bottle in rear hatch
·Rotary Extreme Hood Lift Shocks
Interior
·Interior Plastics color matched
·Carbon Fiber plastic overlay (Blue/Black Carbon)
·Custom Seats
·Custom dash gauges on passenger side (Water Temp, Oil Temp, Fuel Pres.)
·Dual Pod Driver Side (Stoich Meter, Boost Gauge)
·HKS Boost Controller
·PLX Wide Band Air Fuel Ratio Meter
·Dual Probe EGT Gauge
·Pioneer DEH-P770MP CD Player
·Sound Stream XTA480 Amplifier
·Pioneer 3 way Speakers x 4
·Custom hatch Subwoofer Box
·Boston Acoustic G2 12 inch Sub-woofer
·Momo Steering wheel
·Sparco Professional Quick Release Hub
·Battery Re-located to behind driver seat compartment
Suspension and Brakes
·Pettit Rear Toe Control Links and Adjustable Track bars
·Full Delrin Bushings with Lube Groves for self lubrication on all arms
·Replaced all 6 pillow Ball Bushings
·Replaced 4 Ball Joint Boots
·Racing Beat front and Rear sway Bars
·Mazda Trix Front adjustable sway bay links
·Rotora 13 inch Big Brake kit Front
·OEM Rebuilt Rear Calipers
·New Front and Rear Pads
·TEIN Flex 16 point Adjustable Coil-overs with EDFC driver control box
Exterior Body
·Racing Beat Rear spoiler
·99 Mazda OEM Tail Lights
·99 Spec front headlamps
·Erebuni Side Skirts and rear skirts
·Mazdaspeed replica Front Bumper
·Lamborghini Door Modification
·Car is painted in 1999 Honda Civic SI Blue (B-95P) Electron Blue Pearl
Wheels and Tires
·ROJA Wheels with Nitto Tires. 19x9 front 19x10 rear
·Nitto NT555 275/30/19 Rear 80% Thread
·Nitto NT555 235/35/19 Front 80% Thread
Drive Train
·Transmission has all new Syncros and main oil seals
·New OEM Clutch Master and Slave Cylinder
·Stainless Steel Clutch Line
·B&M Short Shifter
·MOMO shifter knob
·Rear-end has new main bearings and seals
·KG Rear-end Brace Support
Security
·Clifford Alarm with passive arming and keyless entry
·LUNAR EYE GPS Tracking alarm with remote control and online Tracking
$30,500.00 with free shipping
RoB
Miami, FL
rob20rx7 is offline   Reply With Quote
