Old 05-07-2008, 10:30 PM   #1
Where to Mount Oil Pressure Gauge?
Hades brought this up in the 3rd gen section and I thought it would be a good topic to discuss.
So you want to monitor the Lubrication system in case of epic failure. I'd want to know where to plumb the system to.
So, Where is the IDEAL place to mount the OIL PRESSURE Gauge probe?
KEYWORDS: OIL, OIL*, PRESSURE, GAUGE, LUBRICATION, MOUNT
Old 05-07-2008, 10:57 PM   #2
Ender
rotors excite me
Ender's Avatar
In the center of the front rotor.
jk idk
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 05-08-2008, 12:14 AM   #3
TehMonkay
Two before both of the pressure bypass valves.
Old 05-08-2008, 01:22 AM   #4
jk idk
Actually, that's the correct answer...
You want to *ideally* monitor oil pressure where it's doing it's job - at the bearings.
If this feasible? No.
The oil filter pedestal is a good, compromise location.
It's aft of the rear OPR, so it's far away from the oil pump - pressure drops first from furthest point of pressure source.
Plumbing an "adapter" isn't that much of a hassle - BIG plus here.
Stock oil pressure sender is about the same location - Mazda knew something we don't?
Old 05-08-2008, 01:52 AM   #5
MaczPayne
Bah!
MaczPayne's Avatar
+1 to the oil filter pedestal as well.
Johnson
TA FC in the works!
Old 05-08-2008, 02:35 AM   #6
Ender
rotors excite me
Ender's Avatar
Oil pedestal is really easy to make aftermarket adapters to fit and it's also close to the firewall to run any lines you need into the dash for said adapters *shrug* I don't know if there are other reasons it worked well there.
'87 TII
