Old 05-06-2010, 03:49 PM   #1
Garfinkles Motor Works
remove the oil metering pump block off
For those who remove the oil metering pump and the injectors I have made a 3/16 thick steel block off plate and a gasket .The stock O-ring is expensive and the gasket will not harden with the heat The plate is slightly larger than the omp foot print so there is more material around the bolt holes .I use flanged bolts to plug the injector holes with a sealing washer under the flange .I cut the OD of the flange down to clear the locating nib on the housing and cut the length to fit . I could not buy the correct length. The cost has has been set at $20 plus shipping .
Old 05-13-2010, 07:01 AM   #2
Strange picture but nice kit for sure .
Old 05-14-2010, 12:08 PM   #3
Dazed and Rotarded
douche bag
Dazed and Rotarded's Avatar
Dazed and Rotarded is on a distinguished road
LOL the pic look's like one of those that you put to your face and pull back slowly with and then you see the ( real ) pic.. very clean looking kit though.. and a great price to boot. i shall be picking one of these up soon from you.
- chris
xbox live - GraveConditions
R.I.P paul gray - # 2
Dazed and Rotarded is offline   Reply With Quote
Old 06-22-2010, 02:12 AM   #4
goracer
goracer is on a distinguished road
I like these better then Bonzai's BOP. Please let me know if you do a run in aluminum.
goracer is offline   Reply With Quote
Old 08-18-2010, 11:06 PM   #5
I have several ready to ship with a gasket ,mounting bolts and the flanged bolts and crush washers to plug the oil injecter holes.
Old 09-28-2011, 07:31 AM   #6
Nice kit that no one needs when they said build it and they will come .
Old 09-28-2011, 07:43 AM   #7
FC Zach
FC Zach's Avatar
If you talk to Jess, ask him if he deals with issues such as this. He could give you many examples which is one reason why he's hesitant to make anything anymore.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 12-04-2012, 09:43 PM   #8
I made these and the ones who said they needed them did not buy.was the price to high,I think not any way I have several to sell .
