Old 10-20-2012, 03:46 PM   #1
irbyjr
irbyjr is on a distinguished road
New member with an RX-7
Hello all. I am Irbyjr, have had a '83 RX-7 GSL since 1984. I have an item or two I'd like some advice on, and will submit a new post for that.
Thanks
irbyjr is offline   Reply With Quote
Old 10-20-2012, 05:49 PM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
You are a tease aren't you? Info? You, car, personal pecadillos? Welcome to the dark side, beware the FB naysayers, they know not whereof they speak.
Old 10-20-2012, 08:24 PM   #3
Viperx7
Viperx7's Avatar
Viperx7 is on a distinguished road
Welcome to the Club.
Mike Chrisman
83 Rx7 Turbo
85 Rx7 GS
89 Rx7 GTU
http://www.cardomain.com/ride/409797
"Don't apoligize for being Patriotic, F**k 'em. TK"
Viperx7 is offline   Reply With Quote
Old 10-20-2012, 08:59 PM   #4
93rx7r1
93rx7r1's Avatar
93rx7r1 is on a distinguished road
Welcome to the club. Post some pics of your rx7 when you can!!
My FD3S Build Thread
2005 Subaru Impreza WRX (daily)
93rx7r1 is offline   Reply With Quote
Old 10-21-2012, 11:50 AM   #5
irbyjr
My '83 RX-7 GSL has an oil leak that contacts the exhaust manifold. My mechanic buddy thinks it is from the timing cover, but he can't find the gasket or whatever to fix the problem. Any leads for help??
No pictures yet but later I hope
THanks
Irbyjr
Old 10-21-2012, 03:30 PM   #6
GySgtFrank
GySgtFrank's Avatar
Do you mean the front cover? MazdaTrix carries a lot of small parts. Check your oil injection lines and pump for leaks, they run along that side. I had a leak there before. If you don't know where they're at download the FSM (Service Manual) from
http://foxed.ca/foxed/index.php?page=rx7manual
The manual will help in trying to track down the leak and many other things. A little hard to diagnose without seeing it.
Old 10-21-2012, 07:31 PM   #7
irbyjr
Thanks a bunch, we'll try.
Irbyjr
Old 11-06-2012, 06:58 PM   #8
cosmicbang
cosmicbang is on a distinguished road
Any progress finding the source of the oil leak?
cosmicbang is offline   Reply With Quote
Old 11-06-2012, 08:42 PM   #9
irbyjr
My mechanic friend thinks the leak is coming from the timing cover and/or the oil pan. Gaskets should be cheap for this, but labor appears to be way up there. I am trying to decide what to do (or what NOT to do).
Comments, suggestions?
Thanks,
Irbyjr
Old 11-07-2012, 12:48 AM   #10
Rot
Rot is on a distinguished road
Welcome to the club! Check your oil metering lines sealing washers, sometimes they leak check with engine running, hope you'll find it!
Rot is offline   Reply With Quote
