Old 12-20-2011, 12:46 PM   #1
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
FS (VA) - ARC Super Titanium Exhaust, BNR S3's, "Axiom" Solenoids, Hi-flow cat, etc.
Hey guys,
So It's winter time, and about time I cleaned out my garage of bits and pieces that I no longer use.. All prices DO NOT include shipping unless specified! All items are available for shipping to the lower 48 states, unless I specify local pick-up.
(Mods please let me know if links to the "other" site are prohibited... I've got them in there for informative/selling purposes only)
Up for sale:
- ARC Super Titanium Exhaust - $1,000
I'm selling this because I moved on to a 4" turbo-back exhaust setup and wanted to share the opportunity to own this great exhaust with another enthusiast. Please see hyperlink for original FS thread as posted by Purerx7/Rx7Boutique.
Exhaust on the dyno at PFS in 2010:
- BNR Stage 3 (sequential) Twin Turbos - $1,200 (Sold)
These have been used, but are still in good condition. There is slight cracking on the middle portion of where the turbo mounts to the stock manifold. I've been told that this is fairly common and nothing to be concerned with though. **These turbo's come with a 99-spec Y-pipe that has been modified to fit, I will not sell them separately**
- "Axiom" Rob Bailey Solenoid set - $400 (Sold)
These are THE solenoids to use if you're still running twins, made orignially by Saxyman990. This comes with a mounting bracket and labeled hoses attached. I can also mail the original installation pdf, though it should (now) be posted in the 3rd Gen FAQ thread. Once these things are properly installed you WILL be able to fully maximize your sequential twins to their full potential without any of the problems normally seen in twins. I was running my BNR's at 17-18psi all day, every day, and I didn't have any problems what-so-ever after installing the solenoids!
Original thread on them: http://www.rx7club.com/showthread.ph...light=Solenoid
- Fluidyne Radiator - $200
Mechanically this is in perfect working order. There is a slight red overspray on the bottom end-tank from a (less than perfect) Maaco paint job after I purchased the car. It's not visible though.
- Hi-Flow Cat w/ Airpump feed - $275
Cat is in good working order, I removed it from my car shortly after purchase since I was not required to run a cat in England.
- 3" Downpipe w/ WBO2 bung - $150
- MS GT-C style Sideskirts - $300
I'd prefer local pick-up on these. They are replica GT-C sideskirts that I purchased from Dragon Performance in England, then I decided to go a different direction but kept the skirts around. These have never been installed, however they do fit up fine from what I remember, mild modifications and sanding could possibly be needed, but that's to be expected.
I have more to sell, I just haven't decided on pricing yet. I will add items as I decide on prices, and post pictures as I take them.
Thanks,
Levi
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
