Old 08-07-2011, 09:57 PM   #1
sen2two
KTEC
sen2two's Avatar
weld wheels and stock wheel studs
Any one here run weld wheels with stock wheel studs? It's a street car so I dont want to go through the trouble of pressing in longer studs into the hubs. Which I heard can be a real pain in the ass. And then i would have to also buy open-ended lug nuts for the wheels i normally run the car on.
I can't see why it would be a problem. But maybe someone here as already done this and has some tips here...
what I have:
What I had:
Old 08-08-2011, 10:39 AM   #2
730RWHP12A
wont be a problem. i have customers with street cars that have been running this setup for years.
rotaryshack.com
Old 08-09-2011, 06:27 AM   #3
sen2two
KTEC
sen2two's Avatar
I figured it would be fine. I just wanted to be sure... Thanks.
what I have:
What I had:
Old 09-09-2011, 09:11 AM   #4
sen2two
KTEC
sen2two's Avatar
I am guessing 20mm adapters would be enough to clear the brakes and not make the tires hit the fender?
what I have:
What I had:
Old 09-09-2011, 10:58 AM   #5
You're asking us without telling us offset, backspace, wheel width, or wheel diameter?
You're wasting our time.
Old 09-09-2011, 09:49 PM   #6
sen2two
KTEC
sen2two's Avatar
I was referring to the 3.5" wide skinnies up front. They will hit the TII brake calipers if not spaced out or shaved down.
I was told before 15mm works best, but I do not want to cut down the factory bolt (which you have to do with 15mm adapters). I would just use longer studs if i was to do that.
what I have:
What I had:
