Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Goopy Performance
Goopy Performance We Manufacture, sell and build Rotary engine parts and accessories specializing in Big horsepower drag and road racing applications. Goopy Performance Stony Point, NY 10980 845-947-0007 Phone 845-947-0047 fax Www.GoopyPerformance.com
Old 01-17-2011, 05:30 PM   #1
GoopyPerformance
Rotary parts manufacture
Goopy apex seals
When people hear about GOOPY APEX SEALS from GOOPY PERFORMANCE for
the first time and learn how long they have been in use the typical
comment is "I have never heard of them ... where have you been?" And
our reply is consistently, "that has been by design! We have been
intentionally maintaining a very low profile, not spending much time
and money on promotion and letting the results that our customers in
selected markets have experienced speak for themselves."
It is not what we say or claim that is important it is what our
customers experience and then say on our behalf that is truly of
worthwhile.
There were several goals that drove the development and the product
direction of our GOOPY APEX SEALS. Among other things those goals
were ...
1. Provide a family of apex seals that will work with EVERY 12A,
13B and RENESIS ENGINE
2. Provide apex seals that we believe provide equal to or
superior overall performance in ALL OF THE MOTOR SPORTS ARENAS from
the drag strip, to circuit, drift and time attack, to hill climb and
rally and to high performance street use, etc.
3. Provide apex seal characteristics that are equal to or
superior to any other seal in every measurable area
a. BREAK-IN - rapid and effective mating and break-in with both
new, GOOPY PERFORMANCE REFURBISHED and used housings
b. COMPRESSION SEALING - in most cases contribute to generating
compression numbers superior to other seals when used in the same
conditions
c. Perform well with NA, NOS and TURBO & virtually any fuel type
d. Handle huge amounts of HORSEPOWER ... and change the dynamic of
the apex seal being the "weak link" or the "achilles tendon" of the
rotary engine
e. Provide an increased MARGIN OF ERROR for mis-tuning or other
system failures that would lead to a blown engine with most other seals
f. Excellent THERMAL PROPERTIES
g. Superior IMPACT STRENGTH so as to handle the extreme loads of
major detinations. Anything can and will break or "bend" ...
however, it is the experience of our customers that GOOPY APEX SEALS
provide a much greater cushion or margin for error
h. Highly compatible with the housing surfaces so as not to cause
HOUSING DAMAGE in virtually all conditions and circumstances
i. LONG TERM USE / high mileage ... we have extremely HIGH
HORSEPOWER drag racers that have gone an entire season (40-50+
passes) without their GOOPY APEX SEALS failing and / or causing any
damage or excessive wear to their housings
j. Provide an apex seal solution that will cost effectively allow
rotary enthusiasts with DAMAGED ROTORS to get back to factory
specifications without changing their seal size (from 2mm to 3mm) and
incurring the time, risk and expense of having their rotor slots
machined to this larger size and arguably sacrificing performance
when moving to the thicker seals. Our OVERSIZED GOOPY APEX SEALS
provide this solution
k. Notwithstanding all of the advantages outlined above, even in
the worst of conditions to date our customers report that GOOPY APEX
SEALS have not fractured or cracked as they might have expected with
other types of seals which probably would have caused CATASTROPHIC
DAMAGE to many expensive components of the engine from housings to
turbos, etc.
l. In the development of our precision manufacturing processes we
have incorporated the ability to ramp our production to virtually any
quantity required. As long as we don't miss our forecast we should
always have our seals IN STOCK
m. GOOPY PERFORMANCE has VALUE ADDED DEALERS in several locations
or you can order directly from us or we will direct you to our Dealer
closest to you in both location and application knowledge
n. Even with all these advantages, GOOPY APEX SEALS are
competitively priced at $350 US MSRP.
Check with our Dealers for their best prices and stay tuned for any
special pricing offered periodically by GOOPY PERFORMANCE
Send your HOUSINGS in to GOOPY PERFORMANCE for REFURBISHING before
your next rebuild and ensure yourself of a far improved mating
surface for your new APEX SEALS with the very high probability of
achieving compression numbers beyond what you have ever
experienced. The $1,000 + that you will save with our HOUSING
REFURBISHING SERVICE vs. buying new housings to get this kind of
compression improvement will more than pay for a first set of GOOPY
APEX SEALS as well as many other components to make yours are truly
top grade rebuild.
We are looking forward to being of service sometime soon.
GoopyPerformance is offline   Reply With Quote
