|  11-22-2010, 03:55 PM | #1 |
| Rotary Fan in Training Join Date: Oct 2010 Location: Ann Arbor, Mi
				Rep Power: 0  |
				Vac hose size?
			So replacing the injectors/injector seals, I broke more than a couple vac lines and went to get some replacement. I took along one of the old pieces and 5mm has a slightly smaller ID than the old pieces. i come home and test fit the hose before I cut it, expecting it to be snug. It's loose! Do I need 4mm hose, or will it seal well enough...[?] Mazdatrix lists 3.5mm and 6mm hose, but the pieces I removed look bigger than 3.5mm, and are definitely smaller than 6mm.
				__________________ 1990 Mazda RX-7 NA; Lucy, after the main antagonist from Elfin Lied. Eventual plans? Something cyberpunk and spicy. |
|  11-22-2010, 04:05 PM | #2 |
| Simply Rotarded Join Date: Jan 2009 Location: Florida
				Rep Power: 17  |
			I'm running the mazdatrix silicon hose and they fit correctly. I would recommend getting them or some that are the same id. They do look alot smaller than the stretched out oem rubber hose, but I believe that the silicon has alot more stretch than the rubber does.
				__________________ LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!! Last edited by LunchboxCritter; 11-22-2010 at 04:11 PM. |
|  11-22-2010, 04:43 PM | #3 |
				Rep Power: 0  |
			SG Imports closes @ 5:30 and I need to prep for class. I'll return the 5mm stuff tomorrow and grab some 3.5mm. I fantasize about the semi-pp 4-port I have planned...sigh.
|  11-22-2010, 05:43 PM | #4 |
				Rep Power: 17  |
			It'll be worth all of the trouble.
				__________________ LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!! |
|  11-22-2010, 08:02 PM | #5 |
				Rep Power: 0  |
			The semi-PP 13B or the silicone hoses? I have no damn doubt that silicone hoses will be worth the effort. But Lucy's hear needs a rebuild soon anyway, and I want her back together ASAP, so I won't wait for the nice stuff right now.
|  11-30-2010, 03:04 PM | #6 |
| Good stuff at low prices Join Date: Oct 2010 Location: TX
				Rep Power: 16  |
			it's the 3.5mm for the small hoses. If you go to autozone they don't have metric hose usually, just fyi.
				__________________ |
|  12-14-2010, 07:53 PM | #7 |
| Pirate Join Date: Mar 2008 Location: Central IL
				Rep Power: 19  |
			Yeah, they have 5/16" rubber hose, and that size fits a bit loose, so you need to zip tie each connection. The 3.5mm silicone stuff works the best for cars IMO.
				__________________ Rotaries:They are NOT that complicated! |
