Old 10-14-2010, 07:24 AM   #1
Stuck turbine housing
I have a stuck turbine housing and I've been letting it soak in PB blaster and deep creep to eat the coked oil, but it's still stuck. Any suggestions that won't result in my center section or my turbine housing being destroyed?
Old 10-14-2010, 07:55 AM   #2
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
I have no experience with turbos, but maybe try heating up the housing
with a propane torch. Getting the housing good and hot should expand it some
and maybe allow the turbine to come free.
Old 10-14-2010, 11:00 AM   #3
You talking stock turbo?
Have you tried to back out the turbine housing bolts already?
There are two that line up with the oil supply and drain flanges.
Just alternate backing the bolts at these positions, and this will help push the turbine housing off the CH.
It may feel like you're damaging the CH, but I have never killed or any of those bolts before.
Old 10-14-2010, 07:34 PM   #4
Non-stock turbo: T60-1. There is only one bolt available to push against the CH and I don't know if I trust it to come off like that.
Old 11-06-2010, 07:21 PM   #5
deadblow has minimal effect
Old 11-08-2010, 11:28 AM   #6
classicauto
crash auto?fix auto
classicauto's Avatar
OA torch, heat up the housing flange where the bolts pass through it to a dull cherry.
