Always Under Construction
CALI Grown E85 Street Car: Project BLACKADDE
So, I started this project last August thinking that I was going to leave the car at the body shop to install the RE-Amemiya ADGT widebody, and then I decided I wanted to do just a few small upgrades.
It began with wanting to port the motor to go single, run E85, completely redoing the suspension, new interior, really putting a brand new car together. I even got some nice valve stem caps. ![]() I'm hoping by posting this thread I'll get some more motivation to finish the project. I'm trying to take her to Seven Stock XII this year, but unfortunately with a full time college students budget it doesn't look like it's going to happen. So, I'm currently in the process of looking for sponsors to bring my baby to life. Ben "Karack" @ Rotary Evolution in Northern California will be the engine builder/tuner, and will be updating me/us with pictures of the engine build. Anyway, hope everyone enjoys the build thread. MOD LIST Some of these parts will change as we get down to the finish. ENGINE: Large Street Port RA 2mm Super Seals Atkins Gasket Kit Atkins Thermal Pellet Atkins Solid Corner Seals OEM 2mm Apex Seal Springs OEM Corner Seal Springs OEM Side Seals OEM Side Seal Springs OEM O Rings OEM Oil Control Rings OEM Oil Ring Springs OEM Front & Rear Main Seal OEM Pilot Bearing & Seal OEM Rotor Bearings OEM Stationary Gear Bearings FUEL: (E85) CJ-Motorsports Fuel Rails Injector Dynamics 6 x 1000cc Kevlar Enforced Aeroquip Startlite Hose Aeromotive 13109 Fuel Pressure Regulator Aeromotive Eliminator Fuel Pump Aeromotive P/N 12304 & P/N 12335 Fuel Filters ATL Fuel Cell SUSPENSION/DRIVETRAIN: Exedy Twin Plate Cerametallic Clutch ZM022SD AtomicRex Aluminum Manual Steering Rack WideFoot SwayBar (Mounts, Bearings, & Spacers) Tri-Point Engineering Front & Rear Sway Bars Super Now Toe Links Super Now Trailing Arms Super Now Tie Rod Ends Delrin Bushing Set OEM Pillowball Bushings/Dust Seals FEED Tower Bar COOLING:: Koyo N-Flow GReedy 3 Row FMIC FEED Throttle Body Elbow FEED Ported Throttle Body RE-Speed Oil Filler Neck RE-Speed Oil Filler Pedestal -10 Super Now Main Pulley Super Now Water Pump Pulley Super Now Alternator Pulley Xcessive Lower Intake Manifold EXTERIOR: RE-Amemiya ADGT WideBody RE-Amemiya AD9 CF Bonnet RE-Amemiya FRP Fender Mirrors Carbon Fiber Hatch Flying 'M' Badges Feed Halogen Turn Lamps OEM 99 Spec Rear Turn Lamps WHEELS TBA!!!!!! Looking for sponsors!!! INTERIOR: RaceShop 4pt Roll Bar Brand New OEM (Gauge surround, hood, chrome bezel, a/c panel, shifter panel, shifter surround) FlyRX7 60mm Tripod OMP WRC Steering Wheel NRG (Quick Release v2.0, Lock, & Adapter) RE-Amemiya Scuff Plates RedLine Italian Leather Shift Boots JDM Arm Rest Pad Sparco Evo CF Racing Seats ELECTRONICS: Microtech LT-10 HKS EVC Boost Controller DEFI BF Boost DEFI BF Fuel Pressure DEFI BF Oil Pressure DEFI BF EGT Innovative LC1 Wideband EXHAUST: Apexi GT Spec Custom 4" turbo Back V-Band TURBO: TBA!!! Not sure what I'm doing yet. MISC: Rotary13B1 Rotor Dipstick Rotary13B1 Rotary Engine Keychain Rotary13B1 Valve Stem Caps FEED Oil Filler Cap FEED PS Reservoir Cap Xcessive Oil Pan ![]() Boxes of goodies. ![]() M2 4 point roll bar. ![]() RE-Amemiya ADGT Widebody. ![]() Some random stuff. ![]() FEED Throttle Body Elbow. ![]() FEED Strut Bar.
BLACKADDE™ | ADGT RX7 | Last edited by MotoTek; 07-22-2009 at 10:59 PM. |
