Old 09-04-2010, 04:28 PM   #1
sen2two
KTEC
sen2two's Avatar
Fuel pump questions for weber set-ups...
I have 3 weber set-ups right now.
45 sidedraft
48 sidedraft
51 IDA (yes, the real deal Racing Beat 51 IDA )
What type of fuel pressure will each be looking for? What size fuel pump? I have used the blue Holley fuel pump before, but i think it was to much pressure?
51 IDA will be on a full PP 13b. The other two will be on moderate to stock motors. Nothing wild for those.
Any tips would be great. Thanks.
what I have:
What I had:
Old 09-04-2010, 06:00 PM   #2
730RWHP12A
3.5 psi is recommended for weber carbs mallory, carter or holley will work fine when ran with a fuel pressure regulator set at 3.5 psi..
however depending on the needle valve in the 51 ida we ran ours up to 6 psi with a internally regulated Mallory 140 fuel pump. we had issues with fuel starvation with other pumps on the p-port....
rotaryshack.com
Old 09-04-2010, 09:04 PM   #3
sen2two
KTEC
sen2two's Avatar
So this one carter pump should be suitable to run all three pumps just fine then. Reason being, I plan on running my basically stock motor at first with my 45 webers because its ready to go. Then later dropping in my 6 port full bridge motor that has the 48's on it. And when i finish my PP motor with the 51's on it, drop that in. I don't want to get a new pump with each motor change.
http://www.jegs.com/i/Carter/180/P40...oductId=748050
what I have:
What I had:
Old 09-04-2010, 09:12 PM   #4
730RWHP12A
you will need a better pump for the p-port. the carter will not flow enough volume too keep up with the p-port. if you want to buy one pump then get the mallory 140 and your done.
rotaryshack.com
Old 09-08-2010, 02:43 PM   #5
jtbshaw
ORD - Old Rotary Dude
jtbshaw's Avatar
Aww snap, I'm glad Robert posted in here about this. I just got my setup fired up on Monday night....TII with tha Shack's 45DCOE blow through. You are suggesting only 3.5lbs Robert? I'm runnning an Aeromotive A1000 pump and regulatin' with a Mallory 4309 FPR. I had it set to 6psi...too much???? The 4309 is a progressive FPR.
Todd B.
(had any of that crazy sauce lately?)
Old 09-08-2010, 05:02 PM   #6
Buggy
I've been Wankeled!
Buggy's Avatar
Buggy is on a distinguished road
I know at anything over 3psi on my 48 IDF i had problems with fuel being pushed past the needle and seat and also external fuel leaks from the carb. Keep the pressure low, but go with a larger needle and seat along with a high flow pump. I'm running a 3mm needle and seat on my halfbridge in my Rx-4.
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place
1974 Rx-4 all original 27,000 miles
1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place
Buggy is offline   Reply With Quote
Old 09-08-2010, 06:14 PM   #7
jtbshaw
jtbshaw's Avatar
That would explain why the car seems to be flooding without ever touching the pedal. I have the pressure set at 6psi. I'll turn it down tonight and see what happens. I still have to dial the timing in as it is a tooth or so off. One thing for sure is that I am not having a lack of fuel.
Thanks for starting this thread Sen2 and thanks for the input fellas.
Old 09-08-2010, 08:37 PM   #8
Buggy
I've been Wankeled!
Buggy's Avatar
You could actually watch the fuel drip from the tubes in the barrels of the carb after the car was shut down. That's how I figured out what was going on.
Old 09-09-2010, 09:42 PM   #9
sen2two
KTEC
sen2two's Avatar
I found a great deal on a basically new Holley Blue fuel pump.
Preset to approximately 14 psi
Flows 70 gph maintaining 9 psi line pressure
Free-flow capacity of 110 gph
If all you need is it to maintain 6psi for a full PP. This should be a nice pump also...
what I have:
What I had:
