Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > MazdaManiac
MazdaManiac www.mazdamaniac.com (AZ) RX-8 tuning
Closed Thread
Old 07-15-2008, 05:11 PM   #1
mazdamaniac
mazdamaniac's Avatar
mazdamaniac is on a distinguished road
AccessPORT for the RX-8
The Cobb AccessPORT for the RX-8 is now available.
This device supersedes any and all engine management devices for the RX-8.
It essentially turns your OE PCM into a tightly integrated stand-alone engine management system.
All fuel and ignition tables can be customized for any application - including all forms of forced induction - and most of the auxiliary functions can be adjusted to suit.
Oil metering, MAF/IAT/EcTS mapping, idle speed, rev limit, cooling fan on/off, accelerator pedal mapping, closed-loop operation, injector scaling and latency, ignition dwell, knock sensor limits, warm-up limits and S-DAIS operation are all independently adjustable and all CEL functions can be disabled as needed through the Calibration Service offered by MazdaManiac and included with every MazdaManiac AccessPORT purchase.
Watch this video for a demonstration of the simple AccessPORT installation procedure, utilizing the MazdaManiac calibrations:
AccessPORT Installation Video
Basic information on the Cobb AccessPORT can be read here: Cobb AccessPORT for the RX-8
The Cobb sub-forum for the AccessPORT for the RX-8 is here: CobbTuning RX-8 Forum
The "Quick Start" guide can be downloaded here: AccessPORT Getting Started
*All prices subject to change. All parts, calibrations and upgrades are offered "as is". Payment must be made in full at time of order. Checks or money orders are accepted, but must clear before order is initiated. Google Checkout and money transfers are also accepted. Purchaser must pay all additional fees incurred by the transaction. ALL SALES ARE FINAL. NO RETURNS, NO REFUNDS. MazdaManiac does not offer expressed or implied warranty on any parts, kits or calibration files offered and accepts no responsibility for any damages, either direct or consequential, caused by the use of these parts or calibration files. For North-American models ONLY. Available to customers in the United States, its territories and Canada ONLY.
©2008 MazdaManiac.com
mazdamaniac is offline
Old 07-15-2008, 05:14 PM   #2
mazdamaniac
All MazdaManiac calibrations for the AccessPORT include the following characteristics:
  • Increased idle speed (830 RPM typical - up to 1100 for the Pettit S/C)
  • Increased OMP output in all load ranges
  • Lower cooling fan turn on points
  • Improved low-gear throttle response
  • Lean fuel targets for light throttle and cruise conditions
  • Removal/cancellation of all or any emissions-related CELs
Further customization can be realized by way of increased engine redline, altered S-DAIS operation and a variety of "novelty" calibrations such as "valet" mode, "anti-theft" mode and other such single-purpose adjustments.
Performance gains are realized through "levels" of fuel and ignition recalibration, allowing for leaner naturally aspirated A/F targets with more aggressive ignition timing or increased torque limits, increased fueling and reduced ignition timing for forced induction applications.
List of CELs masked by the MazdaManiac calibrations for the AccessPORT:
  • P0030 Front HO2S heater control circuit problem
  • P0031 Front HO2S heater control circuit low
  • P0032 Front HO2S heater control circuit high
  • P0037 Rear HO2S heater control circuit low
  • P0038 Rear HO2S heater control circuit high
  • P0133 Front HO2S circuit slow response
  • P0138 Rear HO2S circuit high voltage
  • P0139 Rear HO2S circuit slow response
  • P0171 System too lean
  • P0172 System too rich
  • P0300 Random misfire detected
  • P0301 Front rotor misfire detected
  • P0302 Rear rotor misfire detected
  • P0410 AIR system problem
  • P0420 Catalyst system efficiency below threshold
  • P0441 EVAP system incorrect purge flow
  • P0442 EVAP system leak detected (small leak)
  • P0443 Purge solenoid valve circuit problem
  • P0446 EVAP system vent control circuit problem
  • P0455 EVAP system leak detected (large leak)
  • P0456 EVAP system leak detected (very small leak)
  • P2096 Target A/F feedback system too lean
  • P2097 Target A/F feedback system too rich
  • P2195 Front HO2S signal stuck lean
  • P2196 Front HO2S signal stuck rich
  • P2257 AIR pump relay control circuit low
  • P2258 AIR pump relay control circuit high
  • P2259 AIR solenoid valve control circuit low
  • P2260 AIR solenoid valve control circuit high
  • P2270 Rear HO2S signal stuck lean
  • P2271 Rear HO2S signal stuck rich
  • P2401 EVAP system leak detection pump control circuit low
  • P2402 EVAP system leak detection pump control circuit high
  • P2404 EVAP system leak detection pump sense circuit range/performance problem
  • P2405 EVAP system leak detection pump sense circuit low
  • P2406 EVAP system leak detection pump sense circuit high
  • P2407 EVAP system leak detection pump sense circuit intermittent/erratic problem
Old 06-15-2009, 12:36 PM   #3
mazdamaniac
IMPORTANT INFORMATION FOR ALL MAZDAMANIAC ACCESSPORT USERS
Please read carefully
Before installing your AccessPORT with MazdaManiac calibrations, please watch this video:
Current Version : 1.2.0.0-9386
Current AccessPORT Firmware: 1.3.1.0-8458
Current Dongle Firmware: v0.47
Current "BETA" AccessPORT Firmware: 1.3.2.2-100403
Current "BETA" Dongle Firmware: v0.47
European, Australian and Asian Market Users:
Please be sure to download the "BETA" version of the firmware to ensure your models are supported.
Go to your AccessPORT updater software. Go to the “Tools” drop down menu and make sure the “beta” firmware options are checked.
Restart the updated and then connect your AccessPORT.
Old 06-15-2009, 12:37 PM   #4
mazdamaniac
New users (v4.0 BASE):
Once you have downloaded the newest firmware and APManager, go the MazdaManiac Calibration download area and acquire the proper base calibration for your application.
To verify your proper application, follow the "install" directions below up to the point where the AccessPORT identifies your vehicle. Use the proper calibration based on what the AccessPORT tells you - NOT what you believe your model to be. The AccessPORT asks the car's PCM to identify itself, so it knows best what model to use for calibration purposes. Link:
There is only ONE file for your particular model. If your car has larger injectors or a non-standard MAF pipe or MAF mounting location, follow the e-mail link below in the "11 Deadly Questions" section, provide the requested information and a specialized base calibration will be provided.
Once you have acquired the proper base calibration for your model, follow these instructions exactly:
1) If your AccessPORT is currently installed, uninstall your AccessPORT from your car by following the uninstall directions provided by the AccessPORT menu uninstall option.
2) Remove ALL existing calibrations from your AccessPORT using the AP Manager software. You can save them on your computer if you like for future reference.
3) Update the AccessPORT firmware using the AccessPORT Updater downloaded above.
4) UnZIP the new MazdaManiac base calibration that and move it to the AP Manager and then onto your AccessPORT using the AP Manager software.
5) Install the new Base Calibration on your RX-8's PCM using the install menu option on the AccessPORT. If your AccessPORT identifies your model differently than the selection you have made from the above link, you will not be able to install the new base calibration. Please Contact MazdaManiac with the information presented on the installation screen about your particular model RX-8 if it is different than that which you provided when ordering your calibration.
6) Start your RX-8, bring it to operating temperature and drive it carefully for a few minutes. On boosted applications, avoid going into manifold pressures above 2 or 3 PSI until after you have completed the procedure. For the purposes of the Calibration Service, IT IS NOT NECESSARY TO OBSERVE ANY DISPLAYED PARAMETERS AT THIS TIME (though you may, if you choose to do so). Allow your RX-8 to cool for at least 8 hours and repeat this drive cycle again, allowing the engine to cool completely before proceeding.
If your RX-8 will not run/idle, please uninstall the AccessPORT and contact MazdaManiac using the provided e-mail link below in the "11 Deadly Questions" section.
If you have a boosted application, avoid the boosted ranges to the best of your ability until after you have received your customized calibration.
After performing the two drive cycles, your RX-8 will be ready to provide the required data-log feedback the MazdaManiac for further customization and tuning.
Please read THIS PAGE on Data-Logging from Cobb before proceeding.
Perform the following data-log procedure:
1) Plug your AccessPORT into the RX-8 and start the car. Allow it to warm up thoroughly.
2) Select "Monitor" from the menu options. Press the "OK" button.
3) Select "Set Data Log List" from the "Monitor" menu. Press the "OK" button.
4) check ONLY the following option check-boxes:
  • Equiv. Ratio
  • Engine Load
  • Long Term FT1
  • Mass Airflow
  • RPM
  • Short Term FT1
  • Vehicle Speed
5) Press the "Back" button then press the "OK" button.
6) Select "Data Log" from the "Monitor" menu. Press the "OK" button
7) Press the "OK" button again to start the data-log.
8) After approximately 10 seconds, Press the "OK" button again to stop the data-log. You have just created your first data-log of the engine's idle performance.
9) Take your RX-8 to a safe section of relatively flat highway where you can get the vehicle up to 4200 RPM for several miles at a time without being disturbed. On manual transmission-equipped vehicles, this will be performed in 4th gear. On 4-speed automatic transmission-equipped vehicles, this will be performed in 2nd gear. On 6-speed automatic transmission-equipped vehicles, this will be performed in 4th gear.
10) Once you are up to 4200 RPM, turn on your A/C, headlamps and rear defroster and set the cruise control to hold your speed. On vehicles with no cruise control, hold the vehicle speed as constant as you can with the gas pedal.
11) Press the "OK" button again to start the data-log and continue to cruise for a minimum of 30 seconds.
12) Press the "OK" button again to stop the log and return to your starting location.
You can now download these two data-logs that you have created using the "Advanced View" menu (ctrl-D) in the AP Manager. They will be saved as Microsoft Excel files.
Send an e-mail using THIS LINK, attach the two data-log files you have just created (one at idle and one at a steady cruise) as well as the actual calibration you downloaded and used for these logs and provide the answers to these questions:
The "11 Deadly Questions"
1) Real Name
2) Forum User Name (if you are on the RX8Club.com Forum)
3) E-mail address you used when purchasing your AccessPORT
4) Year of manufacture of your RX-8 (as reported on the AccessPORT install screen)
5) Model (M/T, A/T)
6) Location (USDM-California or Federal, EUDM, AUDM, JDM, etc.)
7) Induction (normally aspirated, turbo, supercharger)
8) Fuel injectors (if different from stock)
9) MAF/intake setup (custom, MazSport, OE, GReddy, etc.)
10) Other relevant mods (ignition, oiling, exhaust, etc.)
11) AccessPORT Serial Number (from the back of your AccessPORT)
You will should receive a confirmation within 48 hours of your submission.
Provided you have followed the directions correctly, you should receive an adjusted calibration within 5 days (business days, Monday through Friday) after receiving your confirmation e-mail.
__________________________________________________ ___________
NOTE:
These are BASE CALIBRATIONS. They provide NO PERFORMANCE BENEFIT over stock and are designed ONLY for the purpose of collecting data for proper calibration of your particular car.
For those with boosted applications, the calibrations will provide enormous amounts of fuel in the boosted ranges and will probably run poorly at above-atmospheric manifold pressures.
If you have a boosted application with larger-than-stock fuel injectors (especially in the primary position), or if you have a non-standard MAF pipe, there is a good chance these will not operate your vehicle at all.
MazdaManiac does not offer expressed or implied warranties on any calibrations offered and accepts no responsibility for any damages, either direct or consequential, caused by the use of these calibrations or the MazdaManiac Custom Calibration Service. Calibration turn-around time may vary. Adjustments may be necessary after the initial calibration process for changes made to your performance parts selection. "Cobb" and "AccessPORT" are registered trademarks of Cobb Tuning. "MazdaManiac" and "Custom Calibration Service" are registered trademarks of MazdaManiac LLC. All rights reserved. ©2009 MazdaManiac.com
Old 06-15-2009, 12:38 PM   #5
mazdamaniac
USERS ON VERSIONS v4.0.1 AND HIGHER
1) Remove ALL existing calibrations from your AccessPORT using the AP Manager software. You can save them on your computer if you like for future reference.
2) Update the AccessPORT firmware using the AccessPORT Updater downloaded above.
3) UnZIP your updated custom calibration and move it to the AP Manager and then onto your AccessPORT using the AP Manager software.
4) Install your updated custom calibration on your RX-8's PCM using the install menu option on the AccessPORT.
5) Start your RX-8, bring it to operating temperature and drive it carefully for a few minutes. On boosted applications, avoid going into manifold pressures above 5 or 6 PSI until after you have completed the procedure. For the purposes of the Calibration Service, IT IS NOT NECESSARY TO OBSERVE ANY DISPLAYED PARAMETERS AT THIS TIME (though you may, if you choose to do so).
ON BOOSTED APPLICATIONS – IF YOU OBSERVE EQUIVALENCE RATIOS (AFR) ABOVE 12.5 AT MANIFOLD PRESSURES OVER 3 PSI OR HEAR AUDIBLE RATTLE OR KNOCK, IMMEDIATELY RELEASE THE GAS PEDAL AND DO NOT ATTEMPT ANOTHER WOT PASS UNTIL CONTACTING MAZDAMANIAC!
  • Equiv. Ratio
  • Engine Load
  • Long Term FT1
  • Mass Airflow
  • RPM
  • Short Term FT1
  • Vehicle Speed
8) After approximately 10 seconds, press the "OK" button again to stop the data-log. You have just created your first data-log of the engine's idle performance.
12) Press the "OK" button again to stop the log.
13) Again, on a safe section of open, flat highway, lower your RPMs to 3000 in 2nd gear (1st gear on the 4-speed automatic).
14) Press the "OK" button again to start the data-log and accelerate at WOT to redline.
15) Release the gas pedal and allow the vehicle to slow and your RPMs to drop and switch to 3rd gear (2nd gear on the 4-speed automatic).
16) When your RPMs have dropped to 3500, once again accelerate at WOT to redline or to the highest safe speed you can attain.
17) Press the "OK" button again to stop the log and return to your starting location.
You can now download these three data-logs that you have created using the "Advanced View" menu (ctrl-D) in the AP Manager. They will be saved as Microsoft Excel files.
Send an e-mail using THIS LINK, attach the three data-log files you have just created (one at idle, one at a steady cruise adn one at WOT) as well as the actual calibration you downloaded and used for these logs.
IT IS VERY IMPORTANT THAT YOU ATTACH THESE 4 FILES OR YOUR CALIBRATION SUBMISSION WILL BE REJECTED!
Then, provide the answers to these questions:
1) Real Name
5) Model (M/T, A/T)
Old 06-15-2009, 01:51 PM   #6
Dang.. I would be interested, but I don't even have an access port..
Herblenny is offline
Old 06-15-2009, 01:55 PM   #7
mazdamaniac
Well, there is a lot to talk about, even if you don't have the AP.
I think a lot of people would be interested - if they could see my sub-forum! lol
Closed Thread
