| 2nd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
Reliable Source
Rep Power: 17 ![]() |
S4 and S5 non turbo engine part out and misc FC stuff, P&P TB
Okay first off I have tons of S4 intake manifolds with actuators and inserts laying around and I wanna get rid of them. They will be going to the scrap yard soon so I'm offering 8 dollars + shipping for any S4 intake manifold (lower or upper)
I have an S5 LIM with actuators and flow friendly sleeves that mimic the pineapple racing inserts for 15 dollars + shipping 13b FC Eccentric shaft with new pilot bearing and dust seal installed 50 shipped I also have a set of S5 NA injectors for 75 dollars shipped, 2 of them are missing lower grommets but they are in good shape. ![]() also have an 86-91 logicon aka hvac controller with the harness cut 20 shipped ![]() ![]() S5 NA ported and polished throttle body, TB mod has been done so there is no thermowax and shows roughly double gain in airflow. includes the TB gasket and TPS, you can use this on an S4 setup if you are running premix or using standalone ECU that requires a wideband TPS signal, other wise to run on S4 electronics you have to make a connector and only utilize the narrowband TPS signal ![]() ![]() ![]() 80 dollars shipped I also have a pair of S5 NA 9.7:1 non turbo engine rotors that have been cleaned ![]() ![]() ![]() perfect shape and pulled from a running motor asking 165 shipped for the pair get em before they go on ebay!!!! the TB is already there but can be taken down easily and I get throttle bodies semi infrequently so be patient and I will have some more S4 and S5 TBs http://cgi.ebay.com/ebaymotors/ws/eB...CA:MOTORS:1123 I have some misc S4 and S5 NA irons that I will sell cheap, some may need to be lapped but they are still within spec, measured for warpage already and checked with a dial indicator for step wear I still haven't taken apart another S4 NA motor so let me know what you may want and I'll let you know if it is usable or not paypal ready and verified part located in central MI Last edited by Fidelity101; 12-06-2009 at 10:42 PM. |
| Tags |
| fc partout, rx-7 parts |
