Old 07-29-2008, 01:52 AM   #1
Some wiring questions...
Ok, so recently I rewrapped my chassis harness, and put it back in the car...
I ran into some funny issues. first, is the fuse box cover. I can SWEAR there was a ring terminal I had to bolt up to the fuse box before, but now I have nothing???
Here's a pic:
Also, I have this random ground, where does it go?
Did I do what I think I did and wrap it wrong? I have some plugs that just dont make sense right now with trying to put everything back in, lol.
Old 07-29-2008, 10:11 AM   #2
classicauto
crash auto?fix auto
classicauto's Avatar
There's definetley a ring terminal for the fuse panel. Thats the main power....
I'll look at my chassis tonite and see if I can find that two wire ground...it looks familiar.
Old 07-29-2008, 08:16 PM   #3
EDIT: Ok, so I feel really stupid right about now!
I was looking at the box with some spare parts in it, and I was like... wait, wtf is this?
It turns out that I completely forgot about the charging harness that also goes in the area. I will have to take it all apart and re-wrap it as well, since it's pretty nasty right now.
PS: I still dont know where that ground in the second pic goes btw, so if anyone has a sugesstion, I will be glad to hear it!
Old 07-30-2008, 01:29 AM   #4
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Hmmm...That ground kind of looks like the one that goes on top of the block, but it's nowhere near that area. I'll go take a look on my car real quick (hopefully it's the same between S4 and S5.)
EDIT: well, I went and looked and didn't see any of those type of grounds in that area. I'll take a better look tomorrow (It [u]is[/i] 3 in the morning).
Old 07-30-2008, 06:49 PM   #5
need RX7
Clean S4 Nutswinger
need RX7's Avatar
I think it's this ground here:
From THIS page (very useful about grounding)
Old 07-30-2008, 08:59 PM   #6
TehMonkay
how would the ground migrate from the engine harness to the body harness? lol
btw, the FSm shows the chassis ground points, all of them, at least the S4 manual does.
Old 07-30-2008, 09:03 PM   #7
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Magic?
Old 07-31-2008, 12:14 AM   #8
ok, I will take a look in the FSM if I can find it for my car... I only have the Haynes one right now...
Old 07-31-2008, 12:41 AM   #9
Boostmaniac
It is an RX7, I learned never to question these things at an early age.
For what it is worth, when I removed my engine, I discovered I had 0 grounds going to the chassis.... again, never question these things. It's like Santa Claus, if you ask questions, he won't ever come to your house again, and that is just a sad sad thing.
Old 07-31-2008, 12:56 AM   #10
ok, i still dont know where the hell that gound goes, but I did get the chassis harness fully re-wrapped and put it back on.
Now, for a question about the fuse box, guys, which side does the black wire w/ white stipe go? I put on the the side with one bolt)
But I thought that maybe it should go on the other sidem, because the stripe wire is a ground? (The side with 2 bolts on it seems to branch out to the other fuses, so maybe the gound should go there???)
Ok, thanks people!
EDIT: LOL at the /\ post!
Old 07-31-2008, 10:51 AM   #11
TehMonkay
i'm not sure what side really, but the wiring section of the fsm tells wire colors and all that
Old 07-31-2008, 12:32 PM   #12
damn you and your so called "fsm"
Old 07-31-2008, 01:54 PM   #13
Well, I looked in the FSM... not much help, because I couldnt find anything...
Old 07-31-2008, 04:03 PM   #14
87TurboII
87TurboII is on a distinguished road
Well on the fuse box on my S5 Vert the black wire with the white stripe goes to the side facing the strut tower on the top bolt (might be the only bolt there on that side). The other solid black wire faces the front of the car connected to the bottom bolt.
As for that ground I was looking and saw that I have one that looks like that and it bolts to the back side of the strut tower right next to the trailing coil pack.
1987 Turbo II
87TurboII is offline   Reply With Quote
Old 08-03-2008, 01:25 AM   #15
Ok, phoenix already told me about the grounds, but THANK YOU for showing me the ground dude, you rock!
