Old 09-21-2008, 09:34 AM   #1
Not enough fuel pressure to FPR
so i have start hunting into why my carb is seeing no fuel. Back checked everything and found that the line running TO the FPR has little pressure / volume. If you hold the hose up, it can barely even flow out. The pump is running, but it seems like i should be getting much more fuel than whats is cranking out.
The pump is a Carter, not sure what model. Is there adjustments on these pumps? There is no restrictions in the system from what i can tell. Purhaps something intake is no longer funcational?
