Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Flyrx7's Pod works
Flyrx7's Pod works flyrx7@aol.com (WA) Specializing in 3rd gen gauge pods
Old 01-26-2009, 01:43 PM   #1
neit_jnf
Boricua!
neit_jnf is on a distinguished road
Talking Quad-Pod gauge setup - prosport white/amber
FlyRX7 center speaker 52mm quad pod - THANKS FRANK!!!!
Hey Frank, I lost a set screw and I need the spacer rings since the prosports are really deep. I got around it by using the gauge's included hoods to cover them but still.
Gauges: AEM UEGO, Boost, EGT, Oil Temp
for the EGT I will install a O2 bung to 1/8 npt adapter to use the stock O2 sensor location. I know it's not the optimal location but I plan on installing it in the rear exhaust runner pre turbo some time later when I get around to pulling the twins.
for the oil temp I will use a Oil Pan drain plug to 1/8 npt adapter to get the temps. I'm used to this location since I was using a VDO that had the sender integrated in the oil pan drain plug.
neit_jnf is offline   Reply With Quote
