Old 12-26-2016, 02:04 PM   #1
FC Zach
FC Zach's Avatar
Antenna mast broke for the last time! Recommendations?
Found my antenna mast broken again. . . not long after recently repairing it
If it's not one thing, it's another. Either the mast doesn't go all the way down, all the time or its broke. I dealt with the mast not completely retracting for many years and finally fixed that issue not long ago by trying different assemblies I had laying around, only to find it broken yesterday.
I'm done with power antennas and would like a tasteful OEM look that is fixed, like this:
What have you done?
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 12-26-2016, 02:11 PM   #2
FC Zach
FC Zach's Avatar
I'm definitely saving myself from the frustration of even considering repairing this again by going with a fixed piece because the last time, I recall myself ripping the POS from the car and throwing it the entire length of my driveway all while yelling obscenities like a mad man. . I don't want to do that again, not with the new neighbors.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 12-26-2016, 05:55 PM   #3
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
iPhone and aux cable has the best radio reception.
03 Dodge Viper SRT-10 Vert
16 MB ML350
Old 12-26-2016, 07:10 PM   #4
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Ditto! Ipod with homemade aux cable to stock 80 head unit on my SA. Rocks
Rammstein!
Sometimes its just the internal plastic mast that needs replaced, as they
break at the point of max externsion and then refuse to retract unless you
push it down. Also, having it automatically go up and down with the radio
power on/off wears them out a lot quicker.
Old 12-26-2016, 10:40 PM   #5
FC Zach
FC Zach's Avatar
push it down.
Sounds easy enough but even if I wanted to deal with this again the mast is no longer available.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 12-27-2016, 08:01 AM   #6
Pete_89T2
Pete_89T2's Avatar
Been there, done that
Is this on an FC? If it is, your options are rather limited if you have the factory wrap around spoiler.... Can't mount a rubber ducky antenna and keep the spoiler, so that narrows choices down to:
1. Fix the stock power antenna. The plastic "chain" in there is the part that breaks. I got the replacement mast kit for mine a few years ago from Ray Crowe. Mazdatrix and Atkins stocked them too, but as usual brother Ray had the best deal.
2. If the mast kit is now NLA, you might try a generic power antenna. Look for a quality unit and expect to pay for it. Try Crutchfield.com and call them for recommendations on a suitable replacement. They do exist, I just don't remember what brands/models.
3. This is a long shot, as it didn't work for me, but some FCs (S5's at least) have a 2nd dipole antenna element embedded in the stock windshield. If you have that, you can plug that antenna in and see if you get decent reception. I didn't - reception sucked. To see if you have it, look for 2 thin wires running vertical along the center of the windshield)
4. Another option is an aftermarket roof-mount patch element or rubber ducky antenna. Or you can source one of those antennas from a late-model wreck in a pick & pull yard. I didn't seriously consider this because I didn't want to have to drill holes in my roof.
Old 12-27-2016, 09:59 AM   #7
Zach has the S4 duckbill spoiler. Maybe look into something like you have pictured Zach, and recontour the base so it fits the body?
Old 12-27-2016, 12:11 PM   #8
chibikougan
chibikougan's Avatar
Remove Mast Plug Hole Wire in...
http://www.rvpartsnation.com/rv-elec...FUOewAod9C8L4g
Old 12-27-2016, 09:17 PM   #9
FC Zach
FC Zach's Avatar
Yep, I have the duckbill.
Checked, not in stock
Honestly, I'm over a power antenna. . I've had nothing but trouble with one in this car.
This was an option and what I had to do I my Celica but unfortunately can't be done in the RX7
Yep, same here. . I don't want to drill into the body especially when there is already a hole for that. .
I do like these but I'm not fond of plugging the hole.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 12-27-2016, 09:35 PM   #10
FC Zach
FC Zach's Avatar
I stopped by a local audio store and picked up an inexpensive universal antenna kit with intentions of using the base only. . where I'll eventually add a short stubby antenna. That's the idea so far.
This is the style shorty I have in mind. . what do y'all think?
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 12-28-2016, 08:51 AM   #11
Sirius
All I'm saying
Old 12-28-2016, 08:55 AM   #12
Pete_89T2
Pete_89T2's Avatar
It looks good, and it will work. The real question is will it get you the kind of radio reception quality you're used to as compared to the old mast antenna? Only way to find out for sure is to try it.
Old 12-28-2016, 01:57 PM   #13
FC Zach
FC Zach's Avatar
Sirius
All I'm saying
This as well as a phone and an aux cable are good ideas. . I use the aux port often so it's not too important that reception is 100%
However it is important that I fill the hole with something other than a plug, even if the short antenna isn't completely functional it should still work some. We will see. I'll order one of these Mazdaspeed pieces soon.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 01-03-2017, 12:22 PM   #14
http://www.cravenspeed.com/the-stubb...nna-for-mazda/
Had one of these on my miata... nice quality and has nice powdercoat finish...
Old 01-03-2017, 03:09 PM   #15
FC Zach
FC Zach's Avatar
Nice, if the eBay piece falls apart I'll try this one.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
half mast, kill it with fire!, need new antenna, pos antenna
