View Poll Results: What oiling setup to use for racing
Leave it stock and run the right engine oil 0 0%
Leave it stock and add some pre-mix 8 53.33%
Disable the metering pump and pre-mix 6 40.00%
Other - I have posted a better idea 1 6.67%
Voters: 15. You may not vote on this poll
Old 04-09-2012, 11:50 AM   #1
magpiemini
magpiemini's Avatar
magpiemini is on a distinguished road
Pre-Mix Oil What - HELP?
I am new to rotary engines and had no idea they had an oil metering pump or you could pre-mix or both. I just read about it in the sticky post.
Where can I read up on this?
Where is this oil metering pump?
What is the recommended setup for racing?
What type of oil should I use?
1984 RX7 GSL-SE
Building for the 24 Hours Of Lemons
magpiemini is offline   Reply With Quote
Old 04-09-2012, 12:28 PM   #2
My5ABaby
My5ABaby's Avatar
I have an FC so I can't talk much about the OMP on the FB, but I took off my OMP and premix with generic TCW3. Some people will say the expensive premix is better, and it probably is, but I haven't had any issues with the cheap stuff.
Community Service Manual
RotorWiki
Old 04-09-2012, 01:52 PM   #3
12arotary
tumor-syphilis-itis-osis
12arotary's Avatar
I run premix and the omp. (85 with a 12a) 128:1- The way i see it if you only run premix you are taking a risk that you will always remember oil in the gas at the proper ratio. Same running only the omp, if it fails or clogs without you knowing for a while it can cause the same issue.
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 04-09-2012, 06:16 PM   #4
orion84gsl
Cheap TCW3 from the parts store. I think I'm currently using Marine grade (whatever the difference may be to others). Mix it 1oz/gal and the car is happy with it. Doesn't hurt the wallet much and I know it's mixing with clean oil. Although it's a fresh rebuild so the oil has been staying clean for a while, but it won't always be that way.
Old 04-11-2012, 05:22 PM   #5
Garfinkles Motor Works
My car is setup to inject Amsoil hp 2 cycle oil from a 3qt tank that I made .
Old 04-11-2012, 08:57 PM   #6
dexspeed
dexspeed's Avatar
dexspeed is on a distinguished road
^ Now that sounds interesting and has peaked my curiosity. You should post up some pics of that. I'm sure there are a lot of people that would prefer to do something like that than add oil every time they fill up with gas.
dexspeed is offline   Reply With Quote
Old 04-12-2012, 05:35 AM   #7
Pete_89T2
Pete_89T2's Avatar
I did a similar setup on my FC, uses the Rotary Avaition OMP adapter and a 1.5 quart tank that I purchased. Here's a link to the "how to" write-up.
http://www.rotarycarclub.com/rotary_...ad.php?t=14945
Old 04-12-2012, 09:17 AM   #8
infernosg
IT'S ALIVE!
infernosg's Avatar
This is a great idea if you have a mechanical OMP or are using the stock ECU or an aftermarket ECU capable of driving the electric OMP. Unfortunately I have neither
I could get an S4 front cover and find a mechnical OMP and rig something up but I don't know how that works with the S5 front counterweight and it doesn't solve the problem that I only have 2/4 oil injector ports (custom intake manifold).
To the OP: I would say this is the best option for your SA/FB. You can run dedicated premix in an auxiliary tank and run some nice synthetic oil in the engine.
Old 04-12-2012, 12:05 PM   #9
magpiemini
magpiemini's Avatar
I still have not found my omp. Can someone tell me what I am looking for and where it is located on my 1984 RX7 GSL-SE 13b?
1984 RX7 GSL-SE
Old 04-12-2012, 12:21 PM   #10
Pete_89T2
Pete_89T2's Avatar
I'm not as familiar with the FB, but it should be in the same place as the FC. Look for it low on the engine's front cover, same side as the intake & exhaust manifolds. It will have some banjo fittings & tubing coming off of it that leads to the oil injectors. The FB will also have a mechnaical rod linkage that goes from the throttle body (GSL-SE model) or to the carb (all other non-FI model SA/FB's)
Old 04-15-2012, 09:08 PM   #11
dr.occa
dr.occa is on a distinguished road
Exhaust side just above the oil pan and towards front of motor.
dr.occa is offline   Reply With Quote
Old 04-16-2012, 10:46 AM   #12
magpiemini
magpiemini's Avatar
Thanks, found it. It seems the Marvel Mystery Oil is just as cheap as the TCW3 at O'Reily's so I bought some. So 1 oz per gallon (128:1) along with the omp?
1984 RX7 GSL-SE
Old 04-16-2012, 11:26 AM   #13
My5ABaby
My5ABaby's Avatar
128:1 is the going rate that most recommend. There's been some debate on using MMO instead of TCW3. I personally wouldn't use MMO, but a lot of people do and don't seem to have any problems.
RotorWiki
Old 04-22-2012, 01:42 AM   #14
Nutsid
Temporarily insane.
Nutsid's Avatar
Premix and OMP. Safer than sorry route. I haven't owned an FB in several years now (and I miss my old ones), but that is how I run in my Rx8 now.
Kindle
Nook
Old 04-26-2012, 09:05 PM   #15
rwatson5651
RX-7 NUT
rwatson5651 is on a distinguished road
Please do not use MMO!!!!!!!!
It was never designed to serve as the kind of lubricant you need.
I use Idemitsu cause it is designed for the rotary, but any TCW3 will work fine.
Using the MMO will IMHO seriously shorten the live of your apex seals, especially if it sees much high rpm use.
The MMO is good for loosening a carbon locked engine, but not for lubrication.
2 cents
rwatson5651 is offline   Reply With Quote
