Old 10-30-2015, 08:00 PM   #1
Islandplans
Islandplans is on a distinguished road
FSM Switch Terminology Question
Hi all,
I'm looking at wiring diagrams and a cluster switch for a '89 w/o airbags. Each connection has it's acronym or abbreviation for it's purpose.
What does 'E' mean? More importantly what does '(E)' mean?
I guess the single E means electricity - but I don't know what the brackets mean. My slot with the '(E)', is open and nothing is connected.
Thanks in advance.
Islandplans is offline   Reply With Quote
Old 10-30-2015, 08:17 PM   #2
C. Ludwig
Rotary Masochist
That's defining what harness the circuit is a part of. E is emissions, F is front, etc.
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 10-31-2015, 12:50 AM   #3
Islandplans
Still Wondering about (E) pin
Hi, thanks for the reply, but in this case it may mean something else. It is part of the Headlight/Dimmer/signal switch combo on a '89. I am more curious what the parenthesis around the E mean. All other pins have various letter..eg 'IL' - illum maybe, and SL, SR, etc. The only one different looks like (E).
Old 10-31-2015, 07:05 AM   #4
C. Ludwig
Rotary Masochist
If this is what you're referring to, what is circled in red, then it's as I'm telling you. Perhaps a screenshot of your own, showing what you're talking about, would help.
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 11-01-2015, 01:34 AM   #5
Islandplans
Hi, thanks for that. I'm sorry, I said 'wiring' when meant that I was referring to a wiring diagram from the Factory Service Manual. I will send pic so you know what I mean. Sending same thing twice in case one pic is too small. I have marked red arrows to a couple of questions I had. The 'E' in parenthesis and two pins that are each labeled 'SL'. If you know what these are, and even the other codes, that would be fantastic,
Thanks again.
Mike
Old 11-01-2015, 11:18 AM   #6
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Copied it to a large format for you, so everyone can see what you are talking about.
I don't know what the abbreviations stand for either, but on the 91 wiring diagram it shows "E" going to chassis ground. I would imagine that "(E)" would be an alternate for the same thing. I don't know this for a fact however.
89_91ClusterSwitch by Kevin Frank, on Flickr
Old 11-01-2015, 03:12 PM   #7
C. Ludwig
Rotary Masochist
That's not an FSM. Google the FSM, download it, and I can help you.
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 11-02-2015, 01:10 AM   #8
Islandplans
GySgtFrank - thank you for copying that in large size. I'm new here and do not know how to do that.
C. Ludwig - I see the same diagram he and I posted in the Factory Service Manual. At least that is what it is called on the following site where I downloaded it from. Maybe it links to an incorrect document? I don't know for certain.
http://wright-here.net/cars/rx7/manuals.html
Old 11-02-2015, 04:07 AM   #9
C. Ludwig
Rotary Masochist
Your using the Hayes manual link. Download this link from that site. It's the true factory manual, not a Hayes aftermarket. The true factory manual will have nomenclature more people can understand.
http://wright-here.net/files/manuals...ingDiagram.pdf
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 11-02-2015, 08:54 AM   #10
infernosg
IT'S ALIVE!
infernosg's Avatar
He's referencing Section T, pages 22-23 in the FSM, which I guess is also copied in the Haynes Manual. From what I've found, Gunny is correct, "E" is ground. I assume "E" stands for "Earth," which is another way to refer to ground that appears to be popular in Japanese literature.
To C. Ludwig's point the "(x)" listed next to wire colors designates the harness or sub-harness that wire is part of. "(E)" being the emissions harness.
Old 11-03-2015, 01:24 AM   #11
Islandplans
I looked at the three dimmer switches in the wiring document and they all look exactly the same. None match what I have - that's where my confusion is.
I don't know how to make those photos bigger, but they are pages Z59, Z60 and Z66.
Old 11-03-2015, 08:09 AM   #12
infernosg
IT'S ALIVE!
infernosg's Avatar
Originally Posted by C. Ludwig View Post
I have the actual 89 manual here. I'll try to get it scanned for you.
The wiring diagrams are incorrect for the S5 harness. I've looked at my own paper copy of the '89 FSM, which includes the wiring diagram, and the online versions of the '88 and '91 wiring diagrams. The pin-outs all show the dimmer switch connector as being the same but this is obviously not the case. The only place I found that clearly shows the difference is in the "Body Electrical" section of the FSM, not in the wiring diagrams. The "Body Electrical" section doesn't give wire colors but it gives the wire function, which can then be used in conjunction with the wiring diagram to determine what wires go where. The trick is knowing how the connector is being referenced (front or back).
Do you still have the original '89 sub-harness to reference?
Old 11-03-2015, 04:44 AM   #13
C. Ludwig
Rotary Masochist
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
