Old 06-29-2015, 08:45 PM   #1
87 t-66
87 t-66's Avatar
87 t-66 is on a distinguished road
Big turbo kit/HKS exhaust/6 T2 trans/SS oil lines/REW mounts/alky kit/T2 axels/MORE..
Turbo kit – master power t-66 turbo, turbonetics .96a/r turbine housing, tial wastegate, hks log manifold, turbo blanket, AEM intake filter – this made 380hp @ 18PSI on my car, a few thousand miles on everything - $1000 shipped
Racing Beat double sheave main pulley - $70
HKS super dragger exhaust – 3k miles or so on it - $700
6 turbo 2 transmissions - $800
Black center console with thick pad and switch plate – no broken mounting tabs - $75
Works bell rapfix 2 hub and hub lock with key - $375
Apexi auto timer with harness $50
HKS EVC EZ - $120
SS oil cooler lines – comes with all fittings and washers - $175
13B-REW mounts for FC chassis - $175
aftermarket radiator cooling panel - $70
FD alt - $70
Cooling mist alcohol kit – comes with controller, pump, tank, new lines, new nozzle, new misc other fittings - $160
T2 axels / half shafts – comes with new rubber boots (not installed) - $200
T2 drive shaft - $70
New energy suspension pinion snubber - $10
New OEM brake master cylinder - $85
New OEM coolant hoses - Heater (at Firewall) to Pipe & Pipe to Lower Radiator Outlet - $25
New OEM S4 waterpump/housing gaskets (thermostat housing to wp housing, wp housing to wp, wp housing to engine, shims) - $20
New OEM rear main seal - $8
New OEM rear pinion lock nut - $5
New OEM rear pinion oil seal - $10
New OEM duct for A/C removal (replaces under dash A/C parts) - $40 shipped
New OEM throw out bearing - $25
MSD plug wires - ~2k miles - $50
T2 axel stub shafts - $50
New T2 axel rubber boot set - $50 / set (4 boots)
S5 T2/FD rear flywheel counterweight with bolts - $115 shipped
S5 T2/FD OEM flywheel with PP bolts - $60 + ship
powdercoated s4 t2 thermostat neck - $40 shipped ($50 shipped with new OEM cap, $65 shipped with mazdaspeed cap)
powdercoated s4 na thermostat neck - $40 shipped ($50 shipped with new OEM cap, $65 shipped with mazdaspeed cap)
untested window switches (driver and passenger) - $70 shipped
untested turn signal switch - $25 shipped
untested idiot cluster - $20 shipped
untested CPU - $20 shipped
untedted headlight switch - $20 shipped
untested wiper switch - $20 shipped
untested s5 logicon - $30 shipped
untested mirror switch - $15 shipped
untested coils (pair) - $45 shipped
s5 fog light switch - $20 shipped
fuel pump resistor/relay - $30 shipped
s4 injector resistor pack - $20 shipped
main relays - $20 shipped
main fuse block - $15 shipped, with cover - $20 shipped, with cover and bracket - $25 shipped
gauge cluster harness S4 or S5 - $10 shipped
87 t-66 is offline   Reply With Quote
