				Rep Power: 13 ![]()  |
			So on my 83 gsl I am lookting into getting new rims. I currently have 16"s on it and would like to stay the same size. But where I am having issues is with the offset. Would anyone happen to know the minimum or maxium off set I could go to on factory set up without needing fenders rolled or wheel spacers?  Amy help would be greatly appreciated!
		#2 | |
				Rep Power: 17 ![]()  |
			Who's Amy? J/K
			There are quite a few people here who will be able to answer this question to much better specs then I can.
			 Waffles - hmmm good
				Rep Power: 0 ![]()  |
			I know this has been discussed on the "other" site but I don't know the answer off hand.
	1980 GS stockport, Fat Nikki, RB Dual Facetfuel pumps, Holley regulator, RB Street port exhaust, 2GDFIS, MR2 MK I electric fans, 2G strut bar, relayed fans, lights and fuel pump, LEDs Project Fat Nikki Budget 12A rebuild Video setup < $30.00  |
			I appreciate it gentlemen.... If you have any information I am willing to take it in.
		#5 | |
			 Professional Stick Poker
				Rep Power: 16 ![]()  |
 Your existing wheels should be marked with the offset, but if they're not you can use straight edges across the wheel to measure from the inside wheel mounting surface to the tire bead and the width of the wheel. (the bead lip isn't included in normal width figures) With the mounting surface dead center of the wheel you have a zero offset wheel. Outward of center is positive offset, (most common) and inward is negative offset. On a side note the closer to zero your offset is, the less strain you will have on your wheels and bearings while cornering. Hope that is helpful.
	1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585  |
		#6 | |
				Rep Power: 19 ![]()  |
 The more positive the offset, the less strain on your bearings... Mazda has been doing it with the RX-7's with the FD being the pinnacle of that theory. The FD runs an 8", +50. (FC turbo runs a 7", +40.) In fact, take a look at all the well-known sports cars that are still running OEM wheels - especially the fronts. Big (positive) offsets are not the prettiest to look at - if you like DEEP DISH - but the positive offsets have performance advantages. If you run the wheel face as far outward as possible, the induces the forces from the rubber gripping the road to a more perpendicular vector in relation to the wheel bearing - i.e. radially. Move that offset inward, or towards "0" or negative, this force starts going diagonally through the wheel bearing. This is actually what prematurely kills wheel bearings, if they are not designed to handle such force vectors outside of stock specs. -Ted  |
			I stand corrected.
			Good info guys.... Thank you!
		#9 |
			So I whent with a 16" 4x114.3 lug and + 20 offset with a 206/55/16 tire. Do you think It will fit without any issues?????
		#10 |
			I know a lot of people run 205/50 15s with about that offset wheel. If the tire width and diameter remains about the same it should work.
