Old 02-09-2014, 09:12 PM   #1
hozzmanrx7
7Club Refugee
hozzmanrx7's Avatar
hozzmanrx7 is on a distinguished road
torque Specs, more than you could ask
ENGINE
SHORT BLOCK
Oil pan bolts 69-95 in-lbs
Tension Bolts 23-29 ft-lbs
Flywheel Nut MT 289-362 ft-lbs , AT Counter Weight nut 289-363 ft-lbs/ Drive plate bolts 32-45 ft-lbs
Eccentric shaft pulley bolt 80-98 ft-lbs
Oil Pump 61-87 in-lbs
Oil Pump gear locknut( the one that sits on top of the gear with the washer with the tab bent) 23-34 ft-lbs
Oil pressure control valve 29-36 ft-lbs
Front cover bolts 12-17 ft-lbs
Oil strainer 61-87 in-lbs
Engine mount on oil pan 46-69 ft-lbs
Left engine Mount 41-59 ft-lbs
Oil regulator value 51-58 ft-lbs
A/C/ and/or P/S bracket M10 Bolt 23-34 ft lbs/ M12 bolt 41-59 ft-lbs
LONG BLOCK
TURBO
Oil Inlet pipe 14-19 ft-lbs
Rats nest bolt 14-19 ft-lbs
Dynamic chamber bracket 14-19 ft-lbs
Water pump 13-20 ft-lbs
Metering Oil Pump 69-95 in-lbs
Exhaust Manifold 23-34 ft-lbs/ Exhaust man. Insulator 69-95 in-lbs
Lower intake manifold 14-19 ft-lbs
Housing/ Manifold Oil nozzle 12-17 ft-lbs
Stock Turbo 33-40 ft-lbs/ Insulators 69-95 in-lbs
Water pipe 17-26 ft-lbs
Air control Valve 69-95 in-lbs
Primary fuel rail 14-19 ft-lbs
Upper intake manifold 14-19 ft-lbs
Secondary fuel rail 14-19 ft-lbs
Throttle body 14-19 ft-lbs
Clutch and Pressure Plate 13-20 ft-lbs
Alternator long bolt 27-38 ft-lbs/ Short bolt 14-19 ft-lbs/ Strap 13-20 ft-lbs
Air pump bracket 14-19 ft-lbs
Air Pump long bolt 12-17 ft-lbs/ Short bolt 17-22 ft-lbs
Crank Angle Sensor 69-95 in-lbs
Stock Oil Pressure Gauge 95-139 in- lbs
Oil Filter pedestal bolts 69-95 in-lbs
Spark Plug 113-156 in-lbs
P/S oil pump 23-34 ft-lbs
P/S pulley 29-36 ft-lbs
Fan Nuts 69-104 in-lbs
Intercooler bolts 69-95 in-lbs
NON- TURBO
Water Pump 13-20 ft-lbs
Fuel Rails 14-19 ft-lbs
Vacuum piping mounting bolts 14-19 ft-lbs
Throttle and Dynamic Chamber 14-19 ft-lbs
Metering Oil Tube 87-122 in-lbs
Intake tube to throttle body 14-19 ft-lbs
OIL SYSTEM
Bolts that hold to body 61-87 in-lbs
Bolts to oil cooler 40-51 ft-lbs
Drain plug 22-30 ft-lbs
Front Oil cooler hose nut 32-40 ft-lbs
Rear Oil cooler hose blot 40-58 ft-lbs
Clamp that holds hose’s together 61-87 in-lbs
CLUTCH COMPANTS
Master to frame nuts 14-19 ft-lbs
Master to hard line 9-16 ft-lbs
Release Cylinder to MT bolts 12-17 ft-lbs
Release Cylinder to soft line 16-20 ft-lbs
Release Cylinder Air bleeder screw 52-78 in-lbs
Clutch Pedal adjustment locknut 8-12 ft-lbs
Hard line to soft line wasn’t in the FSM so if somebody knows what the specs are add it up for others to know
TRANSMISSIONS
MANUAL
Check/fill plugs 18-29 ft-lbs
Drain Plugs A(MAIN one close to engine) 29-43 ft-lbs/ B( TURBO ONLY close to trans mount) 23-34 ft-lbs
Rubber mount 12-17 ft-lbs
Trans mount A(4 Outside bolt) 23-34 ft-lbs/ B(middle nut) 41- 59 ft-lbs
Starter A(bolts)23-34 ft-lbs/ B(nut for wiring) 87-104 in-lbs
Shift lever bolts 69-95 in-lbs
Trans to Engine bolts 27-38 ft-lbs
Cross member for convertible 27-40 ft-lbs
Driveshaft 36-43 ft-lbs
60-69ft/lbs for the flex plate to rear counterweight for light flywheel vehicles and auto cars.
AUTO
Oil pan bolts/bracket 52-69 in-lbs
Vacuum diaphragm bolts 69-95 in-lbs
Oil pipes bolts 17-26 ft-lbs
Bolt/clamp that holds oil pipes together 69-95 in-lbs
Fill/dip stick tube bolts 69-95 in-lbs
Shift lever screws 13-26 in-lbs
Selector lever nut 69-95 in-lbs
Selector cable locknut 7-11 ft-lbs
"he's a tool that moved from being an abusive moderator to a troll that acts like a tool to get his attention now."
John (Jon) Michael Borry = RX7roller02 = skydivr7673 And that's the truth. http://rotarycarclub.com/rotary_foru...t=17659&page=7
hozzmanrx7 is offline   Reply With Quote
