Old 04-16-2008, 08:46 PM   #1
2knob
2knob's Avatar
2knob is on a distinguished road
Pulsing Idle Disappears when Idle Air Control Valve is Disconnected
So what does that mean?
I rebuilt the motor recently, with Atkins 3mm parts, silicone vacuum, HKS downpipe, PFC, and a few new parts. It started the first time, and needed no adjustments. It's run perfectly until a few weeks ago, when I took it down to work on the upholstery, pulling the stock radio/CD in the process.
I start it, accelerated warm-up is fine, but when at temperature, it pulses between 800-1400 rpm. I swapped the Idle Air Control Valve, same problem. I adjust the TPS (narrow=1, full=.44), through the PFC, but no change. Electrical loads and air conditioning appear to have no effect on the problem.
I unplugged the Idle Air Control Valve and the problem, along with the accelerated warm-up, disappears. It idles (without A/C) and runs as good as ever.
So where does one go now? What inputs contribute to the IAC actions?
Thanks for any help...
2knob is offline   Reply With Quote
