Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Bubble Tech LLC
Bubble Tech LLC Bubble Tech- Rotary Apparel, novelty items and Car parts! Dayon, NJ Phone: 732-887-1025 www.BubbleTech.us
Old 03-16-2014, 06:44 PM   #1
muibubbles
Bubble Tech
muibubbles's Avatar
muibubbles is on a distinguished road
Bubble Tech FD Map lids!
Hey guys, we'd like to share with you our newest product!
After many part out threads with dozens of people always asking for map lids, I figured it was time to develop with a more budget friendly price tag!
In addition to replicating this, we have made some revisions to make these substantially better then the stock ones (which are no longer available from mazda)
Cracks- all the interior parts such as the map lid pocket, dash vents, etc are prone to cracking and disintegrating due to the heat making them brittle. Our solution- using a resin with the Heat Deflection temps of 230*+.
Roll pin- The plastic surrounding/plastic dowel pin tends to take a lot of friction and force causing a stress fracture in the plastic hinge. We addressed this by reinforce the area and adding a metal screw in roll pin (also you will be able to install it without removing your door panels)
Spring tension- the spring tension on the cam is WAY to strong- this lies underneath the map pocket compartment, Ideally it replacing the tension would relieve stress but its one more piece that will need to be manufactured. In addition you need to remove your whole door panel to remove it (another chance for more of your plastics to break) Instead we change the angle of the Cam that the spring rolls on- this relieves pressure and less "kick" when it opens and closes (and lowers cost, wahoo!)
Strength- To ensure these last longer than the brittle stock plastics we have increased the thickness of the map lid by ~55%, nice and beefy! In addition we filleted the inner seams to add rigidity. Lastly we filled in the hollow voids on the cam and thickened it.
Here are some of the prototypes as we've gone through various renditions!
We are in the final stages of production and will have these available before the end of march!
Price is set at $95 and will be on our site when the are available for purchase
Bubble Tech
www.BubbleTech.us
muibubbles is offline   Reply With Quote
