Old 11-04-2013, 10:13 AM   #1
jahjahsqc
jahjahsqc is on a distinguished road
87 t2
I pulled off the entire front pulley before realizing what I was doing.
Engine is sitting on the floor in my garage, has not been touched since I removed the center bolt.
Is there a way to look down the hole and see if the washer moved? or do I just need to bite the bullet and pull the front cover.
jahjahsqc is offline   Reply With Quote
Old 11-04-2013, 03:01 PM   #2
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
unless you turned the motor or bumped the shaft it should be ok. put the pulley back on and start cinching it down slowly, if the bearing fell it will begin to get difficult to turn after the bolt is snug, at which point the cover needs to come off.
http://rotaryevolution.net
Old 11-04-2013, 05:07 PM   #3
There's specs to measure the depth of the bolt inside the pulley to tell if the bearing has slipped or not.
This is all shown in the FSM.
Old 11-04-2013, 06:42 PM   #4
jahjahsqc
awesome!
I'll hunt through my manual later.
Old 11-04-2013, 07:56 PM   #5
jahjahsqc
So... just flipped through the entire engine section and tech info section. Didn't find it. Point me in a direction?
Old 11-04-2013, 08:29 PM   #6
chibikougan
chibikougan's Avatar
http://rotarycarclub.com/rotary_foru...ead.php?t=1790
Old 11-05-2013, 07:55 AM   #7
jahjahsqc
Okay. I have in my hands a 1987 factory service manual. I don't see anywhere to check the depth of the bolt. What section is the bolt depth info in?
Old 11-05-2013, 09:41 AM   #8
Pete_89T2
Pete_89T2's Avatar
I have an '89 FSM, and found it in section C, page C-62. Assuming your '87 manual follows the same format, you'll find it in section C, but the page # and specs may be a little different - don't know myself. FYI, below is the content from the '89 FSM. Recommend you find same content in your '87 FSM and use those specs instead.
File Type: jpg e-shaft lock bolt protrusion measurement.jpg (19.7 KB, 34 views)
Old 11-05-2013, 01:47 PM   #9
jahjahsqc
awesome thanks!
Old 11-05-2013, 07:38 PM   #10
jahjahsqc
for the record. 87 manual has the exact same figure and number.
