Old 10-27-2013, 10:58 PM   #1
Anyone using PLX DM-100 Touch?
I have an Adaptronic Select for the FD, an Innovate TC-4 reading from my Innovate LC-2 and two EGT sensors, going through the integration board for the PLX from Adaptronic, and going to the PLX. I'm trying to figure out how to set up the four parameters...Boost, AFR, EGT 1 and EGT 2, but so far it's only letting me set up the warnings for each one and that won't tell it that there are two different EGTs, they would just warn you about the same sensor, if that.
Josh (XLR8) has this same setup other than using the non-touch version of the DM-100, and he has a different menu for his and he's been helping me. I'm wondering if maybe I don't have a current update or something. I have the current tables on it that I downloaded from the site. Or maybe something isn't set up right in the Adaptronic or TC-4, if that's even possible.
Old 10-28-2013, 06:14 PM   #2
I emailed PLX today, this is what I sent...
I'm trying to set up the 4 parameters I want to watch on my DM-100 Touch but it's not giving me the option. I've uploaded the newest tables and I've been through all the different menus but I can't find where to set up the non-OBD II parameters. The only place I can find them is in the warnings tab but I have dual EGTs and the warning would only show two warnings for the same sensor. It will allow me to set up the options for OBD II readings but my car is a 94. My friend has the DM-100 NON touch version and he was able to do it and he was trying to help me but I don't have the same menus he does. I want to read Boost, AFR, EGT 1 and EGT 2. Thanks!
And this is what they replied with...
The new DM-100 touch has automatically sensor detection so that it makes it easier to use the gauge. To change the parameters on the DM-100 Touch, you will have to change the daisy-chain order on your sensor modules to reflect the order that you want to see on the gauge.
Well shit.
