New NGK BUR7EQ / BUR9EQ Spark Plugs
This might be old news for some of you...
I never realized that NGK redesigned these plugs recently? It looks like there's a really minor difference in "reach" spec... Also, the center electrode matterial has been changed? The BIG difference is the with the "semi surface" tip to a regular, single electrode tip? These what Mazda recommends for the RX-8 now? -Ted |
Rep Power: 20 ![]() |
Haven't noticed a thing, I'm getting set of 7s soon. I'll check to see if they're any different from the last set.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
That's if I get a newly manufactured set of course.
Rep Power: 22 ![]() |
Are you saying they look like this?
![]() That is a picture of the RX-8 spec Leading Plug (RE7C-L). If so, that's weird since their catalog shows the old (ie: 'normal') style plug.
If that is the case, NGK is using the same picture for both leading and trailing plugs.
I have a set of NGK RX-8 plugs in the garage, but I'm too lazy to go check :-)
Rep Power: 10 ![]() |
I just bought two sets of BUR9EQ's and a set of whatever the colder plug for the 8 is..... lemme go check and see....
I just ordered a set of NGK BUR7EQP/BUR9EQP's from Rockauto, I'll let you know what they look like when I get them.
#9 |
That's where I got mine from.... Oddly enough, they are the cheapest....
#10 |
RX8 ones look like RX8 plugs, BUR9EQ's look like they always have
#11 | ||
Old NGK BUR7EQ PN#3559
http://www.summitracing.com/parts/ngk-3559 Quote:
New NGK BUR7EQ PN#6917 http://www.summitracing.com/parts/ngk-6917 Quote:
Note between the two... * Material - Nickel Alloy versus Copper * Spark Plug Reach - 0.750 in. versus 21.5mm * Ground Strap Quantity - Four versus One -Ted Last edited by RETed; 02-07-2013 at 05:10 AM. |
#12 | ||
Old NGK BUR9EQ PN#5483
http://www.summitracing.com/parts/ngk-5483 Quote:
New NGK BUR9EQ PN#5777 http://www.summitracing.com/parts/ngk-5777 Quote:
It looks like the 9's haven't changed as much as the 7's? The reach spec has changed... Better for us? BTW, the "old" 7's and 9's are listed "N/A" from Summit. -Ted |
#13 |
That's odd.
This link has a generic image: "Old NGK BUR9EQ PN#5483" http://www.summitracing.com/parts/ngk-5483
#14 |
I would trust things from the manufacturer more than from Summit, they could've messed a few things up when they copied and pasted the info.... I dunno, I'm kinda want to see a new one next to an old one....
#15 |
I just got mine from rock auto yesterday. No changes from the old style, but the box had the same part # (5255 and 4764) as the old style too, so no changes expected.
