Old 03-21-2011, 01:10 PM   #1
streetpower
streetpower is on a distinguished road
Track RX8 build
STREETPOWER RX8 build up
Dyno testing performed by the Streetpower crew on a Dyno Dynamics digital dyno
Engine stock dyno at 158 rwhp with DSC fuse pulled
We did 10 pulls back to back with fuse pulled and with the switch turned off I got a more consistent number at 158 rwhp with fuse pulled.
With switch off I had hp numbers range from 149 to 162 but was never consistent. I did 6 pulls and all the numbers were different.
With fuse pulled 3 out of 4 pulls gave us 158.9, 158.3, 158.7 and 159.
Sprint Booster:
Installed netted no change in throttle response or hp
The engine seam to rev faster but no hard evidence there was any improvements to justify using this device.
There was 2 settings hi and low we made another 10 pulls to verify but no change so we removed it
Cobb AP installed we made a + 10 hp increase to the rear wheels with their stage 1 map but that map is unsafe we saw air fuel go as high as 15.1:1 AF at the top end
Stock with Cobb 168rwhp
Next 10 pulls is with the HKS Hipower cat back
We gained +8 rwhp which averaged out throughout the 10 pulls
Stock with Cobb and HKS cat back 176rwhp
Next up will be a Steve Kan tune in April and a racing beat midpipe
Also got full suspension
Gtspec full bracing frt back and under
HSD coil overs
Progress sway bars frt and rear
Endlinks?
Track rims and tires
Weight savings
streetpower is offline   Reply With Quote
