Old 02-10-2011, 12:10 AM   #1
FC Zach
FC Zach's Avatar
Question Eccentric Shaft End Play?
The specifications within my Haynes manual specify that the "Standard" is .04 to .07 mm with a max of .09 mm. I started off with my "K" spacer and had a reading on my dial gauge of .015 (give or take .002 mm). I felt that may have been a little too tight so I borrowed an "X" spacer from jfaplanet and received a reading of .02 mm (maybe .002 mm more). IIRC the "S" and "T" spacers are uncommon and was wondering if the reading I received from the "X" (.02?) was good enough, or is it too tight still? ? ?
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 02-10-2011, 12:28 AM   #2
FC Zach
FC Zach's Avatar
http://www.youtube.com/user/jfaplane.../0/l6AFE8bYFDM
Here is a video if it works.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-10-2011, 12:38 AM   #3
.0015" is what I shoot for. Basically a little tighter than Mazda's min. What are you torqueing the front nut to? You know you can tighten it a little more to snub it up a wee bit. I usually go for 110-115ft/lbs.
Old 02-10-2011, 03:01 AM   #4
FC Zach
FC Zach's Avatar
I didn't torque it at all, just ran a battery impact on it and the rear nut for a few seconds (probably around 90-100ft/lbs given the tools specs) just for fitment purposes but now that you mention it I can see the specified torque being crucial to the fitment process. Only thing is, is that will possibly get me a little less play. If you successfully run yours with a run-out of .0015mm with no issue then I'll stay with the "K" where I had the initial .015mm run-out and of coarse rechecking it after properly torquing the front and rear.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-10-2011, 06:27 AM   #5
FC Zach
FC Zach's Avatar
Sorry TT, misunderstanding on my part. I now see that you were stating your measurement in inches which is .038mm. So now my question is,
Who has a "S" or "T" spacer? Can these be purchased from Mazda still?
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-10-2011, 08:18 AM   #6
Are you sure those are in mm and not inches? I can't tell from the vid. It's rare that spacers need to be changed out.... unless you changed bearings or rotors.... I'd try Rob @ Pineapple. He told me once that he has a drawer full of them if I needed an odd size. MT probably has them as well and I'm sure Ray Crowe can get them as well.
Old 02-10-2011, 10:04 AM   #7
FC Zach
FC Zach's Avatar
Yeah, all new bearings (came in the RX8 stat. gears). Just ordered some spacers from Atkins, got both S & T to be sure.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-10-2011, 10:42 AM   #8
My5ABaby
My5ABaby's Avatar
So to clarify Zach, the issue is that your shaft isn't getting enough play?
Community Service Manual
RotorWiki
Old 02-10-2011, 10:54 AM   #9
Old 02-10-2011, 11:32 AM   #10
Zing!
Old 02-10-2011, 07:13 PM   #11
FC Zach
FC Zach's Avatar
Wow! Should've seen that commin
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-10-2011, 07:33 PM   #12
That's what she said
Old 02-10-2011, 11:01 PM   #13
FC Zach
FC Zach's Avatar
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-11-2011, 07:57 AM   #14
My5ABaby
My5ABaby's Avatar
Originally Posted by FC Zach View Post
Is that the look on her face afterwards?
RotorWiki
Old 02-11-2011, 01:02 PM   #15
Leave it to this group to turn a serious thread into a dick and fart joke.
poop
