| Tires,Wheels,Suspension,Brakes Info about Tires, Wheels, Suspensions, Brakes, etc. |
Rep Power: 14 ![]() |
First, both the front and rear rotors are single piston, one side, YUCK, even the old English cars used at least two pistons. Any suggestions for better calipers?
Second, I was able to open up the front caliper wide enough for new pads but the rear caliper was a problem. I could not press the piston back, they do work so I know they are not stuck. I could not use new pads, had to put the old pads back in for now. Is there a trick or special tool for those rear calipers? |
The rear calipers have to be turned back in there is a couple small notches on the piston that a tool fits into and turned clockwise ( the tool is usually like a small block or sometimes a pair of needle nose pliers will work)
____________________________________________ 1976 Cosmo needing lots of work 1993 Rx-7 410 RWHP single turbo toy 1985 Rx-7 toy/project car 411HP stoplight terror 2001 Dodge ram 4wd.parts hauler 2016 Ram 2500 cause its a hemi 2006 VW TDI commuter __________________________________________ I guarantee there's a pregnant redneck teenager somewhere in a shitty trailer park that thinks "Ebola would be a lovely name for their child"...
#3 | |
The parking brake was not your friend.Try to find a repair book it may save you some time and money .
^ To what he said, you can download a copy of the factory shop manual here: http://www.wright-here.net/cars/rx7/manuals.html
The 1984 & 1985 editions will have your GSL-SE model covered. |
#6 | |
