Old 10-20-2010, 07:10 AM   #1
tweiss3
Mazda Lover
tweiss3's Avatar
i know you guys are good
Since i am pretty new to working on rotaries, and i cant always spot issues as easy as i can on my other car, i need some help. I read the fsm about a million times, but some of the diagrams suck.
The car: 91 (s5) non turbo
Only mods include new magnaflow direct fit cat system (single 3 way cat), corksport catback (2.5"), and cone filter replacing the airbox ( mini filter on the air pump intake tube). Premixing half to one. Completely stock otherwise, supposedly. I am replacing the O2 sensor today if i can pick one up from autozone.
The symptoms, related or not:
The car sometimes has issues staring cold. It will almost start immediately, then not and i have to flood start it which it tuen starts immediately. Oil doesnt smell like fuel or seem to be breaking down (doing uoa this saturday when i change it).
When the motor is warmed up, and i just start driving even with a sligjter heavy foot, and i come to a stop, i smell fuel. It goes away after about a good 15 minutes of driving in rull warmup.
What i have seen that may be odd:
The charcoal canister, has the two upper tubes that go to the fuel lines/evap system, but there is one coming out the bottom going to nothing?
This pictire is right below the throttle body:
Should those two capped nipples be going to something? Should i replace the caps? They appear warn and cracked.
Your guys help is appreciated.
Old 10-20-2010, 07:37 AM   #2
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Rotaries=very cold blooded=your harsh cold start.. they run rich.. especially in the cold, which is probably why youre smelling gas.. i was worried about the same thing with mine when i first got it.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 10-20-2010, 06:06 PM   #3
That "valve" right in the middle of the pic that has the bigger nipple that's capped is the sub-zero assist valve.
Mazda has instructions to "delete" those damn things.
So don't worry about that...
I dunno what the smaller one on the left is for.
Old 10-20-2010, 06:12 PM   #4
project86
project86's Avatar
is that the same thing as the cold start deal/wax pellet deal?
'90 GTUs
'10 Toyota Prius
Old 10-20-2010, 06:52 PM   #5
tweiss3
Mazda Lover
tweiss3's Avatar
yes. I also forgot to mention, i get a wierd idle at times, it goes up and down from 900 to 1400, is this normal.
Old 10-20-2010, 06:57 PM   #6
project86
project86's Avatar
i know mine was kinda erratic for a while... now im trying to remember why.. some of it was due to vacuum leaks but i thought there was something else that was causing it too.
'90 GTUs
'10 Toyota Prius
Old 10-20-2010, 07:03 PM   #7
tweiss3
Mazda Lover
tweiss3's Avatar
I wonder if those caps rotted out and cracked are causing it, but every other vac line looked and felt prestine.
Old 10-20-2010, 07:10 PM   #8
project86
project86's Avatar
if those caps are bad that could cause some.. man.. i wish i could remember if there was something else.....
'90 GTUs
'10 Toyota Prius
Old 10-21-2010, 04:52 AM   #9
No.
Old 10-21-2010, 07:54 AM   #10
project86
project86's Avatar
^^Thank you
'90 GTUs
'10 Toyota Prius
Old 10-21-2010, 09:56 PM   #11
NoDOHC
NoDOHC's Avatar
The idle is slowly revving to 1400 rpm, then dropping quickly to 600-700, right?
This indicates that the TPS is not adjusted correctly. The ECU thinks that the engine is at 0 throttle, and it isn't (thermal wax). This results in it revving until it hits the decel fuel cut, resulting in rrrrrrrrrrrrr -- duh rrrrrrrrrrr -- duh, etc.
Old 10-21-2010, 10:13 PM   #12
tweiss3
Mazda Lover
tweiss3's Avatar
Yea, it does exactly that, but not all the time. So what do I do to fix it? Im broke after the new Oil pressure switch, O2 sensor, fuel filter and oil change. Man do bill suck.
Old 10-22-2010, 07:55 PM   #13
project86
project86's Avatar
you can get a TPS tool that will plug into the diagnostic port and you can adjust it that way.. its cheap so if it doesnt work you wont be out much at all.
'90 GTUs
'10 Toyota Prius
Old 10-25-2010, 11:49 AM   #14
tweiss3
Mazda Lover
tweiss3's Avatar
So, saturday, i replaced my oil pressure switch so my gauge would work again (unfortujately didnt work) but i found my fuel smell source. The canister runs a soft line to hardline to softline to the drivers side, and is left un attached to the motor. My fsm shows it to jeed to be attached to the oil filler tube, is that correct? I have only one nipple on the filler tube instead of two shown on the fsm. If it doesnt attach there, where does it attach, i couldnt chase it down.
