Old 07-06-2009, 04:26 PM   #1
stezhead54
stezhead54 is on a distinguished road
Question Oddball 20b conversion
So, i'm currently in the middle of a 20b build. There's a lot more people on this forum who have done the build than the others that i'm on, so i'll post some of my questions/issues on here and see if anyone can help me out. First question/issue would be, if i want to keep the stock turbos what do i have to have controller wise. I've got a Microtech ltx12s to do the ems stuff. Second question....can i hook up the stock knock sensors....if so, how? If not what do i have to have to have a knock sensor that works(so i know if the engine is knocking or not) Third and final question for now, Has anyone used cop(coil on plug) coils on there build? If so, how did they work, or didn't they? So, i guess that's all for now, if you have any questions for me, just let me know and i'll be happy to answer. Here's a pic of the engine sitting in the car to see how far it is. I've still got to fabricate some mounts and do the driveshaft welding yet, but other than that it's almost ready to turn over. Just a couple more parts, and a couple more fabricating issues and i'm ready. On a side note, i'm doing all of the fabricating, and all of the construction myself, so if it doesn't look professional, it's because it's not. When it's done though it'll look as if the engine was meant to be in the car. So, until i do get it finished, here's one picture of the car.
stezhead54 is offline   Reply With Quote
Old 07-07-2009, 10:37 AM   #2
What the hell car is that in?? The GM master cylinder has me thinking Camaro.
Which would be awesome.
Old 07-07-2009, 11:59 AM   #3
stezhead54
That would be correct. It's an 86 iroc z the engine died on me, and i had the 20b on hand(was going to put it in a v6 firebird, but that didn't work out) so i decided to drop it in.
Old 07-07-2009, 12:12 PM   #4
Originally Posted by stezhead54 View Post
i had the 20b on hand, so i decided to drop it in.
I get so tired of saying that... /sarcasm
Old 07-07-2009, 01:59 PM   #5
Bryan@BNR
Bryan@BNR is on a distinguished road
I'll trade you an LQ4 motor with all its sensors and EMC for that 20b
Bryan@BNR is offline   Reply With Quote
Old 07-07-2009, 02:22 PM   #6
stezhead54
and explain why i would want to do that? I took the 305 out of it to put this in.
Old 07-07-2009, 02:51 PM   #7
He wants another 20B.
Bryan is a whore.
Old 07-07-2009, 03:19 PM   #8
classicauto
crash auto?fix auto
classicauto's Avatar
Damn thats a sweet swap.
We want more pics, I don't care if its not done yet.
And please put one of those "out of a job yet keep buying foreign" stickers on the back when its done
Old 07-07-2009, 03:56 PM   #9
stezhead54
I'll take some more pictures today and put them up for everyone to see. Anyone have any answers to my questions though?
Old 07-07-2009, 04:09 PM   #10
LMAO!!! This is awesome! Can't wait to see it all finished up and 'beating' V8s on the road
Old 07-07-2009, 04:13 PM   #11
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Holy crap, that is awesome.
TitaniumTT may be able to help you out with the turbo stuff, he has a 13B-RE running the twins sequentially. Not sure about the similarities between 20B twins and 13B twins, but it's worth a shot.
Old 07-07-2009, 04:35 PM   #12
If you want to run 20B twins, call BNR. He does an upgrades for 20B twins and people are making great power (In AUS)!
Old 07-07-2009, 04:53 PM   #13
well first he needs to get info on the knock sensor then info on the "coil on plug" thing....he seems to have the EMS covered already...
I've heard of people using FC coils or LS coils but don't know about teh specific type you mentioned.....your best bet is to chill for a bit here and wait for the other 3-rotor peeps read this thread and tell you what they used.
Old 07-08-2009, 12:46 AM   #14
stezhead54
Pictures for the masses
So i took some more pictures tonight. They aren't much better than the other ones cause it was dark out....maybe in the near future i'll have to roll it outside and take some pictures. Also, the coils i'm using are coils from a v6 where they sit down a well right on top of the plugs. I went this route so i don't have to worry about wires or anything. All i have to do is wire up the coils, plug them in, and start it up(very simply put) As for the knock sensors, they're just the stock ones that came with the engine. What i'm trying to figure out is how i'm going to hook them up to either the ecu, or say a light inside the cabin to tell me if there's any knock going on.
Old 07-08-2009, 12:01 PM   #15
classicauto
crash auto?fix auto
As far as the knock sensor's go, you'd have to check the outputs/inputs on the microtech to see if there's a channel that can read them. Most good ECU's have this feature, but I'm not sure on the microtech. However, what I do know of the microtech is that it has EXTREMELY limited inputs/outputs available, IIRC, the LTX12s only has 1 auxilary output to be used for a fan, fuel pump or whatever. So if I had to guess, I'd say you can't hook the knock sensor(s) up to the box.
But check in your manual.
You really can't hook up a light to the sensors themselves, they just create tiny amount of voltage based on the level of knock. And there will be a threashhold where you have "knock" but not enough to worry about and this level varies between engines and sensors.
