Rep Power: 20 ![]() |
Identifying Transmission/Clutch Noises
Here's a list I made up of the common complaints I saw on an "unnamed" forum.
![]() I Hear the Sound When... Clutch pedal not pressed, or in neutral - Replace the input shaft bearing. Clutch pedal pressed halfway - Replace the throwout bearing. Clutch pedal fully pressed - Replace the pilot bearing. In all gears, regardless of clutch position - Temporary: get better transmission fluid. - Real Solution: transmission rebuild. I Hear... 1st gear whining - Replace the input shaft bearing. Grinding when shifting - Temporary Fix: shift more slowly and get better transmission fluid. - Real Solution: replace the synchros, shift fork, and/or clutch. Notchy shifting - Temporary: get better transmission fluid. - Real Solution: replace bearings and/or synchros. |
