Old 02-26-2009, 05:50 PM   #1
bigtony08
obsessed rotard
bigtony08's Avatar
bigtony08 is on a distinguished road
ZE v6
Hey guys has this swap ever been done? i know the drivetrain would work with this engine but would it be worth doing? i mean how is the after market and so forth?
bigtony08 is offline   Reply With Quote
Old 02-26-2009, 05:52 PM   #2
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
ZE is which engine? I'm wanting to think 350z? If so, I saw an FD in a mag with the swap done a while back.
Old 02-26-2009, 06:04 PM   #3
Mazda MX-6 V6
Old 02-26-2009, 06:44 PM   #4
bigtony08
obsessed rotard
bigtony08's Avatar
sorry should have said that but yea the mx-6 v6
Old 02-26-2009, 08:48 PM   #5
Wouldn't be worth the trouble. That engine is VERY much designed to be FWD.
Better options if you wanted to keep it Mazda are:
-MS Miata engine
-FE3
-F2T
All of which are 4 cylinder, only the MS and F2 are boosted, and the F2 is only SOHC.
In other words, its cheaper to make power with a rotary.
Old 02-26-2009, 09:00 PM   #6
bigtony08
obsessed rotard
bigtony08's Avatar
thanks i was just wonder if its been done
Old 12-05-2009, 12:47 AM   #7
reaper
2slow4u
reaper's Avatar
reaper is on a distinguished road
i was debating doing an f2t in my fb. has anyone done this?
(i have searched)
my hoarse is amazing
sincityrotary.com
a place for las vegas rotary enthusiasts
reaper is offline   Reply With Quote
Old 12-05-2009, 08:50 AM   #8
(i have searched)
Not in an FC that I am aware of, but in B-series truck it has been done many times.
For RWD configuration you would need:
-B2200 trans, clutch, flywheel, starter
-custom mounts
To run it you would need:
-EDIS conversion (trigger wheel based ignition)
-custom flange to swap the intake around (it faces the firewall, the intake is 2-piece, so this is not as hard as it sounds)
-thermostat housing from a 323 (stock thermostat housing will hit the firewall)
-Megasquirt or similar stand alone ECU
To make power you need:
-FMIC
-hybrid turbo (For T-bird turbo)
-550cc injectors (FC injectors are direct swap)
-Custom exhaust
If you want to do it, I suggest you buy my '89 626 Turbo as a starting point
Old 12-06-2009, 12:45 AM   #9
reaper
2slow4u
reaper's Avatar
wow that was a no B.S. parts list! you a really knowledgeable person. i'm going to have to start reconsider this swap again lol.
sincityrotary.com
Old 12-06-2009, 09:50 AM   #10
I do what I can. It also helps to have both cars in your driveway.
Old 12-09-2009, 01:08 AM   #11
reaper
2slow4u
reaper's Avatar
haha true, all i have to work with is s stroll through pic a part
sincityrotary.com
Old 01-16-2010, 09:10 AM   #12
SouthSideSlider
SouthSideSlider's Avatar
SouthSideSlider is on a distinguished road
i seen a miata with the ZE V6 before not sure what tranny he ran though.
the SHO ford/yamaha V6 will bolt up to a T5 with a Bellhousing from a mazda B3000
2000 Acura Integra GS: daily driver
1990 Mazda RX-7 GTU: parts car.
1986 Mazda RX-7 base: under the knife.(no sunroof!!!)
1989 Volvo 745 turbo: B230ET,19T turbo,850 Turbo injectors,HKS Manual Boost Controler,Port/Polish,Oversized valves,titanium valve springs,M-Cam,G80 locker,modded AW71 transmission.
SouthSideSlider is offline   Reply With Quote
Old 01-16-2010, 03:13 PM   #13
put it in a miata, stay away from rx7s.
